At Porter Airlines, a rewarding Aircraft Engineer career awaits. Licensed Aircraft Maintenance Engineers with a Dash-8/Embraer E Jet Type Rating and Heavy Turboprop or other transport category aircraft Type Rating, hired between now and June 14, 2024, will receive a one-time $25,000 signing bonus.
Reporting to the Manager, MOC, Outstation Maintenance and Contract MROs, will work in support of Porter’s fleet in SOC coordinating maintenance activity.
Duties and Responsibilities
MOC is responsible for technical dispatch and will use AMOS, Porter's maintenance system, to ensure all scheduled and unscheduled maintenace is carried out and released prior to dispatch
Monitor deferred defects as part of technical dispatch
Work with Operational Planners in support of Work Packs that are issued to overnight aircraft at main bases and outstations and adjust should aircraft swaps arise
Work directly with flight crews and dispatchers each time a defect is reported to SOC
Assist flight crews with MEL procedures
Coordinate AOG road trips system wide, including parts, tools and hangar space
Coordinate with third party MROs if unforeseen maintenance away from a maintenance base is required
While liaising with engineering, work directly the associated OEM should technical assistance be required
Update each aircraft's weight and balance information via established spreadsheets and AOC software each time a change is made
Monitor for the fleet for repeat defects
Actively participate in Porter’s Safety Management System (SMS) including, reporting hazards and incidents encountered in daily operations; understand, comply and promote the Company Safety Policy
Qualifications
Possession of a Transport Canada Aircraft Maintenance Engineer License (M2 or E rating) required;
Proven technical aptitude with at least 3 years’ experience and/or endorsed on Dash-8-400 and/or Embraer Regional Jets and/or equivalent type of aircraft preferred.
Experience working on a wide range of airframe systems such as electrical, navigation, flight controls and turbine engines.
Ability to obtain necessary Transport Canada security clearances
Successfully complete the company background and pre-employment screening tests.
Flexibility to work shifts and overtime.
Location
Toronto (Billy Bishop Toronto City Airport - YTZ)
