Recent sim evaluation
Brokecplpilot
Post by Brokecplpilot »
Have a sim evaluation coming up. Has the sim evaluation changed from the previous ones? Also any idea of the current failure rate on the sim evaluation ?
CaptApollo
Re: Recent sim evaluation
Post by CaptApollo »
It hasn't really changed. Just read the other threads that describe it.
Incoming1
Post by Incoming1 »
Brokecplpilot wrote: Sun May 24, 2026 5:48 pm Have a sim evaluation coming up. Has the sim evaluation changed from the previous ones? Also any idea of the current failure rate on the sim evaluation ?
I also have my sim eval in June
TheAmazingDisgRace
Post by TheAmazingDisgRace »
I've seen a few questions lately about the Jazz sim evaluation, so I thought I'd share what I know. The good news is that the sim eval hasn't really changed over the years and there shouldn't be any major surprises if you've prepared appropriately.
They'll let you fly from whichever seat you're most comfortable in. If your partner prefers the same seat, you'll simply swap for the PM duties.
The profile is fairly straightforward: a normal takeoff, a hold, an approach with a missed approach, and an emergency scenario that leads to an engine shutdown and single-engine landing. More than anything, they'll be looking to see that you're receptive to instruction, can work effectively as part of a crew, and demonstrate good CRM.
Good luck!
fox12
Post by fox12 »
For the hold. is it raw data hold, VOR or GPS using the FMS ?
rwy31
Post by rwy31 »
Hold over a VOR if I recall and you have to determine hold entry , ILS approach as well is raw data , no use of FMS
