Question about Icing
Hi all,
I am going to be flying a single engine low wing piper in the next 2 weeks to various locales in Northern Alberta. I was wondering if anyone had any suggestions for potential actions to be taken on inadvertant flight into icing?
Is it better to decend? To turn around right away (fuel permitting)? Keep going?
I know it's very abstract to try to give advice without particular facts, but I'm just looking for general pointers.
Thanks,
JM
Thanks,
JM
- invertedattitude
The best tip Pre-flight pre-flight pre-flight.
Barring an unforseen weather buildup, stay out of cloud if you can (VFr or IFR?) if you have ice buildup descent only works if its actually warmer lower, and if IFR can prove to cause other problems.
If you encounter ice, without de-icing gear, my suggestion would be find a place to land ASAP.
I'm with everyone else here in stating the obvious. You can't get iced up if you don't fly into the clouds. Make a 180 and know when nature has ya licked. Don't be the hero and try to push. DO pay attention to the likelyhood of carb ice. That can sneek up on ya and give your ticker a jump!
Play safe
P.S. If your experiance level is low and/or the equipment you have to use is not up to the task, I have to say that November isn't always the best time to be planing adventures in the sky. I know, I learned the hard way! When winter has a tighter grip on the land, the weather improves a lot.
Play safe
There are moments when everything goes well; don't be frightened, it won't last. - Jules Renard
Beware the limited vis in winter (anytime it's cold really) too... you can find yourself goign from 5 miles of crappy vis to in cloud pretty quick. The old 180 saved my bacon twice in one flight. If ever any doubt, land. So what if you're stuck in butt-f---k nowhere for a day or two. Atleast you'll be able to tell the story.
As for the climb/descent, it all depends on what kind of system, how powerful the airplane is, rate of accretion, etc etc... with the 180, you know for SURE that it was clear where you came from a second ago. Even if you have to land off-field, still better that groping aroung in-cloud with no IFR experience hoping for things to go your way.
2 things about icing, if you're not sure it's above freezing below you, CLIMB...you can always descend even with a load of ice
you can get ice in clear air ( and I have) but it is rare, once for me in 30 odd years
Two 180's? So you basically just kept going in your original direction!mellow_pilot wrote:The old 180 saved my bacon twice in one flight.
"Yeah. There is a problem. You...because you're dangerous. You're dangerous and foolish - and that makes you dangerous! Now, let's cut the...crap. We've got a plane to fly. Let's try to be on time, okay?"
~Val Kilmer, Saturday Night Live
Re: Question about Icing
Perhaps this will be of interest. http://www.tc.gc.ca/CivilAviation/comme ... 0r_att.htmJimmy Mack wrote:Hi all,
Thanks,
JM
ok...i'm not a pilot so i'm not sure what's safe what isn't....we had a Cessna (206) in a few days ago....he was flying IFR . after he shut down i noticed a light layer of ice in the leading edge of the wing...the strut...the gear and the tail....pilot just knocked it off took his fuel and off he went. is that the best kind of weather for a 206?
Watch out for the pineapple express ( lots of warm moist air from the pacific) in the spring and fall ( have seen it in the winter but not that often) it has a tendency to bring freezing rain to the northwest corner of the province on the B.C. & NWT. borders. As for any other pointers I think they've bean well covered by the other post's.
Never ever believe that you won't pick up ice unless you are in IMC. I've flown more than a few hours in the north I've loaded and a/c with ice many times while maintaining legal VFR. Look at your OAT and steer around areas of falling precip - particularly rain if your OAT is at or below freezing. The good news is that on most VFR days you can see these pockets of precip and visually maneuver around them. Snow showers aren't as bad in terms of airframe icing - usually just some light rime, but the forward vis can easily drop to zero and you'll be on the gauges.
Best advice I can give is check wx, call stations along the route before departure to check conditions and always have an out.
Have fun and be sure to post pictures - some of us don't get to have interesting trips like that anymore.
Back out on that road again
Turn this beast into the wind
There are those that break and bend
I'm the other kind
I'm the other kind
- invertedattitude
I've never seen anywhere written that this form of de-icing is legal, while I know everyone does it, there are approved standards for de-icing/anti-icing an airplane, while I can understand removing a light clear ice by hand may work, you also can miss a lot of it as it can be very hard to detect, especially on a painted surface.AEROMONKEY wrote:ok...i'm not a pilot so i'm not sure what's safe what isn't....we had a Cessna (206) in a few days ago....he was flying IFR . after he shut down i noticed a light layer of ice in the leading edge of the wing...the strut...the gear and the tail....pilot just knocked it off took his fuel and off he went. is that the best kind of weather for a 206?
Best bet, either throw it in a hanger and let it melt and dry it off, or get properly de-iced if you're in that much of a hurry.
- invertedattitude
Oh and JM, another tip, pack yourself a decent 1-2 day survival kit in case god forbid you have to setdown in the middle of the bush somewhere, being warm and having some food and water could save your butt if you're stuck having to put down to avoid crashing!
Oh and like we say in PEI, "Land with the Potato Ruts, not against them!"
Good call. Earlier this weeek (sunday?) there was light to moderate freezing precip in the forecast for Whitecourt, Peace River, Slave Lake, Ft StJohn, and Ft Nelson I believe. Then it changed to a sigmet for severe clear icing in freezing rain NE of Fort St John going SE ward to Slave Lake.Howie wrote:Watch out for the pineapple express ( lots of warm moist air from the pacific) in the spring and fall ( have seen it in the winter but not that often) it has a tendency to bring freezing rain to the northwest corner of the province on the B.C. & NWT. borders. As for any other pointers I think they've bean well covered by the other post's.
Make sure you read that portion in the GFA of Icing, turbulence and freezing level. Usually icing in cloud is rare in the low levels since the air is soo cold and there isn't a great deal of water around to make the air humid. Remember to look at the sigmets.
Still this winter's been exceptionally moist and with the easterly flow down low and westerly aloft the wx has been strange. This is a good year to exercise great prudence when dealing with potential freezing rain and icing conditions.
Look out for warm air aloft, especially when these fast moving fronts rip through. Monday I had an encounter with moderate clear ice through 17 000' in the tops of some Tcu's and had to divert, and later that day we saw a fully developped winter Cb topped at over 21 000'.
Read the forecast, call FSS hourly en-route for wx updates, and ask centre for pireps ahead of your route. As already stated if you get into even trace amounts of ice, get the fuk out as fast as possible.
Cheers, CJ.
- Shady McSly
"KNOCK KNOCK" This is the real world calling, av8rpei! There's nothing wrong with what he did. Get off your high horse for a moment and use your head man. The guy removed a little bit of ice on the leading edge, so who gives a crap how he did it? Or is Type 1 or a hangar the only options in your myoptic little world? Do you know that float pilots often pour lake water on the top of their wings to remove a bit of morning frost? The HORROR!av8rpei wrote:...I've never seen anywhere written that this form of de-icing is legal...AEROMONKEY wrote:...he was flying IFR . after he shut down i noticed a light layer of ice in the leading edge of the wing...the strut...the gear and the tail....pilot just knocked it off took his fuel and off he went...
Did you also know that there's this magical thing some pilots use to remove snow off the wings in places where there are no deicing services readily available, and would be a waste of money even if it was available? yeah, it's called a 'broom'.
The Legality is the 'clean wing concept' as I'm sure you're aware of, not the 'type 1 concept'.
Sorry, but you needed a little shot, buddy.
- Pith Helmet
From TC:av8rpei wrote: I've never seen anywhere written that this form of de-icing is legal, while I know everyone does it, there are approved standards for de-icing/anti-icing an airplane, while I can understand removing a light clear ice by hand may work, you also can miss a lot of it as it can be very hard to detect, especially on a painted surface.
Where conditions are such that ice or snow may reasonably be expected to adhere to the aircraft, it must be removed before takeoff. Dry, powdery snow can be removed by blowing cold air or compressed nitrogen gas across the aircraft surface. In some circumstances, a shop broom could be employed to clean certain areas accessible from the ground. Heavy, wet snow or ice can be removed by placing the aircraft in a heated hangar, by using solutions of heated freezing point depressant fluids and water, by mechanical means (such as brooms or squeegees), or a combination of all three methods. Should the aircraft be placed in a heated hanger, ensure it is completely dry when moved outside; otherwise, pooled water may refreeze in critical areas or on critical surfaces.
The chief export of Pith Helmet is Pain.
