Known and Forecast Icing
Hello All
A subject that has come up recently amongst myself and my colleagues is the differance between Known and Forecast icing. The relevance of this topic is important to us because the aircraft we fly is not certified for known icing.
Now I have looked at CAR's 605.30 and the way I read it is that Known and Forecast are the same with regards to a plane that isn't certified. So if I were to take off into an area where icing was forecast that would be illegal.
There seems to be some discussion about what the differance is though. Some people are saying that just because it is Forecast doesn't mean that it is Known. It would require a pirep from someone actually confirming that the icing exists.
Any input would be greatly appreciated
Heartland
Heartland
The problem is fellas, that I have flown all day in forecast icing and have never seen a speck of ice. Flown within minutes, identical routes as aircraft calling heavy ice and have again not seen any. I have also flown when no ice was forecast and ended up with moderate to heavy. If you used icing forecasts as your go-no go decision you will never do much aviating during fall, winter or spring. IMHO ice forecasts are the least reliable weather forecast given to flight crew. Does you aircraft have any icing capability at all?
- Empress Chief
The only difference between "known icing" and "forecast icing" is the forecaster being aware of it's existence. If it's forecast, then you're not going to fly into it. If it's NOT forecast, but a PIREP says it's there, (ie. known) you're STILL not going to fly into it.
The term "known or forecast icing" is just covering all the bases, and providing a worst case scenario. Icing is icing, whether it's expected or experienced, the dangers are the same.
JR
JR
- Empress Chief
You're not following me here. If you have a situation (ie. MEL restriction) where you are not allowed to fly into "known or reported icing conditions", it's saying you can't fly into an area where there's a forecast of ice, even if there's no reports of it, OR into an area where there are reports of icing, even if there's not forecast for it.
The PIREP doesn't qualify, or disqualify the forecast, (as in your alternate example), it protects against situation where a forecast hasn't been issued, but icing conditions still exist.
Hope that helps.
JR
Hope that helps.
JR
- i aint gettin rich
icing
my thought if its forcast then tech its known.. maybe there is none in but really if you are going on a flight and its says freezing rain, are you going to fly through it or try and avoid it.. most of the people i fly with wont go. why take the chance..stay above it or below it..
