IFR Question
movingagain
IFR Question
Hello
In the Cap Gen under " Alternate Weather Minima ", in the box, "NO IFR Approach Available", i'm not exactly sure what is meant by, "forecast weather must be no lower than 500 Feet above a minimum IFR altitude that will permit a VFR approach and landing"
Does it mean that for example, the MDA is 600 AGL for the approach...the weather must be at least 500 ft above that? So 1100BKN/OVC? Or are they refering to 500 ft above the MSA or MEA or ?
- Cat Driver
it'll be based on the lowest official ifr altitude in that area, based on whatever you can find. If all you have is area altitude on the enroute chart then you have to use that, if the airport happens to be underneath an airway, you can use the MEA or MOCA for that airway. It has to be an IFR altitude, any IFR altitude. If you descend and are still in cloud, you miss, otherwise if you get the field in sight, you land. Giddy-up!
Drinking outside the box.
sierra yankee
If you're talking to ATC they should advise you of the minimum IFR altitude when clearing you out of controlled airspace. As above, if the airport doesn't have an instrument approach and there's no airway nearby, we'll usually either use a 100-mile safe alt off a navaid or a minimum vectoring altitude if we've got one. At least in the sectors I work, the 100-mile safes are usually lower. If we've got both, obviously we'll give you whichever is lower.
If you don't have the field at that altitude, another possible option if there's another field nearby with an instrument approach is to go there, shoot the approach to get under the deck, then cancel IFR and .. run to the original destination. Obviously ATC isn't going to suggest this but pilots will often request it and we'll accommodate. It's a pretty good option if there's say a 2,000 foot ceiling and the minimum IFR altitude is 3,500.
Hope this helps.
Hope this helps.
movingagain
thank u all for your time.
in this situation..i'm trying to find out if, when wanting to use an airport with a GPS approach only as an alternate, what weather would i need on the GFA. In the Cap Gen it says u must use the " NO IFR Approach Available" when a GPS approach only is available.
This particular airport has a GPS approach only with an MDA which is also the circling height, both 600AGL.
I would think that this means 500 ft above the MDA of the GPS approach?
Thanks again
Thanks again
- Axial Flow
movingagain
Flying Nutcracker
movingagain
Well, the reason i stated whether or not our GPS was IFR certified was to say that if we do have to go to the alternate...we can legally go down to the MDA of the approach at the alternate..not just the MEA of the airway above the airport or the AMA if there is no airway nearby.
Anyways...think i've received my answer. "a minimum IFR altitude that will permit a VFR approach and landing" Sounds like the minimum IFR altitude is the MDA of the GPS approach at the alternate. So i'll add 500' and use that as my minimum weather on the GFA to use that airport as an alternate.
Thanks all...end of topic
I think you need to be careful with that one. If you read Note 1 following that alternate weather stuff it says that these requirements are based on TAFs. If using a GFA it must be 1000 feet above the lowest HAA etc 3 miles etc.
And you only have to use "No IFR approach Available" if you don't meet the above requirements listed A-D
a) completely independent approach at destination
b) ....
c)...
d)....
at the beginning of the bottom paragraph it says "otherwise". Read the COM secition 3.16 about the GPS it lays it all out in there.
If you have met A-D then you can use 800-2 or 300-1 for your GPS approach.
BTD
b) ....
c)...
d)....
BTD
[quote="movingagain"]Well, the reason i stated whether or not our GPS was IFR certified was to say that if we do have to go to the alternate...we can legally go down to the MDA of the approach at the alternate..not just the MEA of the airway above the airport or the AMA if there is no airway nearby.
Thanks all...end of topic[/quote]
So just to double check....Is your GPS certified for IFR approaches and are you trained to fly IFR approaches(if flying commercially)?
movingagain
movingagain
