big AC jet circling VFR near Barrie, ON Sat morning?
Saturday morning (June 30) I saw a large jet circling east of Barrie, down at maybe 3000'-4000' AGL or so, cranking it around (30 deg bank) in a blue hole between cumulus clouds.
It looked like an Air Canada A330 or maybe even B777.
I'm wondering what it was doing there!
Special sight seeing flight??
(Wonder if it is related to the one mentioned in someone's thread "Just saw AC 777-200LR at CYYZ" about the previous day.)
Normally one doesn't mix it up with maneuvering big jets down low in class E, so it gets one's attention.
I was almost level with it at 3000'+, in a skydiving C-182, about 5 miles SW of it. Our pilot was in contact with Toronto Centre and heard that the jet was indeed VFR, and the jet was made aware to stay clear of the drop zone.
My dad happened to be in a small homebuilt at the same time, flying towards the same area from the east, seeing it 5 miles infront of him.
There were quite a few Cu around, bases maybe 3500', but a blue hole existed over Lake Simcoe -- so it seems as if the pilot picked that area and altitude to avoid punching through cloud during its wide turns. After watching the jet circle it climbed rapidly between or through the Cu to the south before disappearing from view.
On Sunday morning, from the ground, I again saw what looked like the same jet out west of the Cookstown drop zone.
Mitch Cronin
Justwannafly
Truth is stranger that fiction because fiction has to makes sense.Mitch Cronin wrote:Anonymous man claiming to be an Air Canada employee, and speaking only if off the record and voided of all identifying data, says the captain wanted to see his cottage.
What you need to know is, how to get what you need to know.
This is not a retreat. Its an advance to the rear.
There are only 10 people in this world. Those that understand binary and those that don't.
Here are some ideas for some baby t-shirts that you can buy for your friends who are proud new parents:
http://www.tshirthell.com/store/product ... ductid=499
http://www.tshirthell.com/store/product ... ductid=365
well the difference between a 777 and a330 is the winglets.. did you see any winglets? if you did, it must be a330 or 340..
http://www.airliners.net
Never buy 1$ tickets
I was working that particular morning. It was the B777 on a crew training flight. YYZ-YUL-YYZ. Inbound to YYZ they asked for a routing over YEE decent to VFR to cancel and then pick up the IFR back to YYZ. It was down as low as 3000ASL.
On a side note the day after a B767 did relatively the same thing down to about 5000ASL.
Hopethat clears it up
IFRATC
IFRATC
