Skyservice
rammingspeed
Skyservice
Post by rammingspeed »
Does anyone have any info on the airline, routes,days off, aircraft, any on order, where they overnight?
rs
EyeOh
Post by EyeOh »
Are they hiring yet? Last I heard they'd laid off, hadn't heard if everyone was even back yet.
centerstored
Post by centerstored »
Does Skyservice have any means of commuting?...jumpseat or passes? How about days worked?
captaingomes
Post by captaingomes »
Skyservice is hiring a few pilots right now, but if you haven't received a call yet, time is running out and you'll need an internal reference.
However, some Skyservice news hot off the press: http://www.canadanewswire.ca/en/release ... c2481.html
B757FO
Post by B757FO »
rammingspeed,
To answer some of your questions.
There was threat of layoffs last 2 years in a row now but never came to happen. We had a contract under negotiations and was probably the only reason behind them. Right now there are no layoffs. There are some pilots on LOA's. They will run about 22 aircraft this winter. 11 757s and the rest airbus. The hiring they are doing will be for both types I imagine either the 320 or the 757. You will spend some time away from home at various places in Canada and also down south depending on aircraft type you are on. There are no passes or co agreements for travel but I believe they are working on a jumpseat agreement but I am not sure. I am guessing that they will need to hire allot of people this winter as many have left to AC. Deployments are a part of life here at ssv though. With the news about being sold perhaps now will be some expansion but as with anything it would only be a guess. Bases are YYC or YYZ but you will not see a YYC base. It will be for YYZ. Hope this helps.
B757FO
centerstored
57,
thanks for the info. How many days are you guys scheduled for on these types? Thanks in advance.
B757FO
Days
Post by B757FO »
cs,
We have 11 GDOs a month off. Airbus does more turns down south versus pairings. Boeing you will be away for days at a time. That being said this can change so who knows. Hope this helps.
B757FO
