Fueling King Airs.
Clark Kent
Fueling King Airs.
Post by Clark Kent »
Hi there!
Trying to figure out if the fueling steps (main-aux) on the king airs are the same on every type. Looking to compare 90-100 (A_B),200, 350.
Also wondering about how much pounds (Main-aux) tanks contains.
Thanks!
What's a fueling step?
The -100 takes 374 USG the A100 takes 470 USG
The 200 takes 544 USG and the 350 takes 539 USG
You do the math how "much" pounds that is.
Samolin
Fueling King Air(s)
Post by Samolin »
It depends on what kind of wing spar modifications have been done on the aircraft.
It is best to fuel in the following order... Main,, Main,, Aux,, Aux,,.... and you wouldn't go wrong.
Some 100s also have a Nacelle fueling capability.... just follow the directions in the following AFM and you will do fine!
Beautiful and Stable plane!
Go Guns
Post by Go Guns »
Both the 200 and the 350 have limitations that state you're not allowed to fuel the auxs unless the mains are full.
sinjin
Post by sinjin »
With 99 % of all king airs
Nac tanks first, then mains, auxs are always the last to be filled
winter sucks
F/O Crunch
Post by F/O Crunch »
on the a100, Main= 1350lbs/tank so 2700lbs total.
Aux = 275lbs/tank so 550 total.
Cant say i'm totally sure about all the king airs, but in order to get fuel from the aux tanks you need flow from the main tanks.. so if you're silly and burn all your main fuel first you go down with 2 bombs in your wings. :shock:
sinjin
Post by sinjin »
On the one hundreds? does it not go through the Nacs not the auxs?
winter sucks
nightguy
Post by nightguy »
100 fill nac first then fill wing.
a100 fill wing first then aux.
90 nac first then wing
200 wing then aux
The FCU is a BFM
V2
Post by V2 »
ya... ima go with night guy on this one for once he's right :P
rigpiggy
Post by rigpiggy »
F/O Crunch wrote:on the a100, Main= 1350lbs/tank so 2700lbs total.
Can't say i'm totally sure about all the king airs, but in order to get fuel from the aux tanks you need flow from the main tanks.. so if you're silly and burn all your main fuel first you go down with 2 bombs in your wings. :shock:
Not entirely sure either but all the photo's I've found have Auto, and Override on the Fuel control Panel. pretty sure this is so you don't overflow the mains while power is on on the ground without the engines running. the override would/should allow use of the aux fuel during an engine out situation. Anyone can correct me if I'm wrong.
Starsky
Post by Starsky »
You are wrong for the A100, F/O Crunch is correct. I don't know about other King Air models.
hazatude
Post by hazatude »
nightguy wrote:100 fill nac first then fill wing.
200 wing then aux
Confirmed
2R
Post by 2R »
Ah grasshopper you want to learn the art of KUNG-FU FUELING
You must first learn the song as sung by Carl Davies
"Everyone was KUNG-FU FUELING
Everyone was Kung-FU Fueling
Top it off top it off top it off
Man those caps came off in lightning
In fact it was a little bit frightning
Until this funky non china dude looked a bit like Hazatude
Said get your hose off my pants leg thats Rude
Cause we don't fuel in lighting anymore
Chorus
Everone was Kung-Fu Fueling
Those guys were fast as lighting
Everyone was Kung-Fu Fueling
Top-it off top it off top it off
Please feel free to add the next lines !!!
Note that Carl Davies original version of Kung-fu fighting is still played at all the Euro-trash disco nights and Karaoke bars all over the planet
So having a fueler version ready for an avcanada karaoke night would be fun :wink: :wink:
