Page 1 of 1
Aircraft de-icing
Posted: Thu Sep 13, 2007 1:17 pm
by laticsdave
With the wonderful Lower Mainland winter weather not too far away, I’m wondering what methods other School’s are using for ground de-icing procedures (other than those lucky enough to be able to hanger their entire fleet!).
In the past we’ve used a hot water & methyl hydrate mix, but as methyl hydrate is a controlled substance (& toxic as hell!), we don’t want to continue using it!
Let me know what de-icing procedures you’re using.
Thanks.
Posted: Thu Sep 13, 2007 1:26 pm
by hazatude
Herman Nelson and a bunch of towels. Takes time but works well.
Posted: Thu Sep 13, 2007 1:36 pm
by laticsdave
hazatude
Holy cralp - Haza's top poster - what happened to Cat Driver (I've been off-line too long it seems).
Posted: Thu Sep 13, 2007 3:18 pm
by Adam Oke
Glycol in a spray applicator
Posted: Thu Sep 13, 2007 3:33 pm
by Ref Plus 10
Isopropyl alcohol mixed with hot water
Posted: Thu Sep 13, 2007 6:44 pm
by comanchepilot
Our school uses RV Antifreeze (can't remember what chemical it is - pink fluid) and has it in the chemical/lawn and garden sprayers with the screw on top/pump handle thing.
One of our PA-44's had some non-STC'd engine pre heaters installed which our AME removed and affixed to the bottom of the metal sprayer cans.
They are set on a timer so they are always ready in the morning. The fluid is so thin that once it is on and melts the ice, you can T/O without removing the fluid.
Just be dead sure there is nothing on the wings still, because just spraying this on doesn't always do enough.
Posted: Thu Sep 13, 2007 7:16 pm
by 4blue
- Urine (fresh out of the "shipping container"... not cold)
- if the water (lake) is warmer, then a bucket of lake water that you pull on a string from the top of the wing
- Type 1 in little spray bottles from crappy tire
- hot water from inside
Posted: Thu Sep 13, 2007 7:28 pm
by costermonger
Room temperature isopropanol, spray application. Works like a dream for heavy frost, but any significant amount of ice and it's a waste of time. In that situation, half an hour in a heated hangar is much more efficient.
We tried out heated type 1 kit last year, where you screw a heater element into a hand sprayer. Turned out being a lot less useful than the isopropanol. Not much pressure and basically no volume, which (from what I understand about type 1) makes it pretty much useless. Got nice and hot in the sprayer, started cooling as soon as it left the nozzle.
