Aircraft with 24v power supply
Torn
Post by Torn »
Can anyone provide me with single engine aircraft with 24v power supply? I have been searching google and it apprear's as if the C-206 and C-207's do? is that correct? Can anyone confirm or add any they know of.
Thanks,
Torn
MZUNGO
Re: Aircraft with 24v power supply
Post by MZUNGO »
i think that most aircraft run on 24vdc system.
xsbank
Post by xsbank »
I think so too - less/smaller/lighter cabling required.
cessnafloatflyer
Post by cessnafloatflyer »
Most Cessnas mid 70s onward... for good cranking too. C-182, 185, 206, 207, 210 etc. The Beaver as well.
Youngback
Post by Youngback »
On the 206's, 207's and 210's that I have experience on, they were all 12/14 volt systems.
1000 HP
Post by 1000 HP »
If you have ever lifted an original Beaver Battery, or an Otter battery, you'd think they were 96 volts...
CID
Post by CID »
From what I recall, Cessna switched to 28 volts in the mid to late seventies on all their singles. These days, most airplanes manufactured since then are 28 volts. I don't think I've encountered any 28 volt Cherokees though so I'm not sure what happened with the piper line but their newer twins were 28 volts. I think the old Apaches and Aztecs were 14 volts.
One main advantage of the 14 volt systems was the commonality with automobile electrical parts. Not much of a factor anymore though.
There of course are still alot of the older 14 volt airplanes around. And there are even a few "no volt" Citabrias and J3s etc. around!
