If this was your office what would you be flying?
Took this on Friay any idea what aircraft?
- panel.JPG (98.53 KiB) Viewed 2773 times
Its not having what you want. It's wanting what you've got.
- Cat Driver
Re: If this was your office what would you be flying?
Airbus A380?
Hurricane or Spitfire?
Something British I think.
Looks kinda like a Spitfire?
- Ref Plus 10
- Location: Wherever the winds may take me...and the paycheque
Muahaha Cat is wrong! That there's the new Boeing 787 Dreamliner.
It is the space shuttle Atlantis
small penguin
Dont you folks see the big red button? This photo is clearly that of a B2 cockpit
You are getting warm it is British, I guess the glass cockpit is throwing you off ;>)
For a little more help see additional shot below.
And interestingly enough one of the pilots who will fly it was a member of the international team that completed the Operational Evaluation of the A380 and became one of the first pilots to qualify on what is now the world’s largest passenger jet not that it will help you much.
- portcockpit.JPG (91.71 KiB) Viewed 2328 times
angry inch
Looks like a Hawker Hurricane.
Only one flyable in North America.
- starboardcockpit.JPG (79.96 KiB) Viewed 2172 times
just curious
- Rank Moderator
Altimeter, airspeed, oil guages and yoke all suggest a spitfire. The angular cut on the bottom right part of the panel suggest a later mark, as does the compass mirror. Reflector gunsight is missing.
A Mark IX perhaps?
A Mark IX perhaps?
This shot gives a lot of clues.
- gun mount.JPG (58.28 KiB) Viewed 1611 times
just curious
- Rank Moderator
It has the leather footstraps like the mark IX
just curious
- Rank Moderator
well its a biplane with a rear gunner, I'm gonna go with swordfish as well
You got it! I thought someone would spot Bob Spence's name in the cockpit. This shows Bob and Chris Hadfield, now in the Vintage Wings Hangar undergoing engine rebuild.
- swordfish9.jpg (130.47 KiB) Viewed 2050 times
I made an emergency landing at Spence's field a few years ago due to structural failure. After he towed my plane off his runway we went in the hangar to see that stunning aircraft. It is a work of art!
unknowingly upsidedown
Is there a reason why the...looks like the RPM gauge, is on such a cant? is it to get '0' right at the bottom?
I suspect you are right on the RPM gauge anyone know for sure?
This shot is of the torpedo operators panel which is located below the pilots panel. You can just see the circullar seat . He would actually be lying on his stomach beneath the pilots seat looking through an open hatch in the floor. A small windscreen swings down to protect him from the wind.
Suddenly those Air Canada economy seats don't look so bad!
- Lower panel.JPG (72.17 KiB) Viewed 1611 times
I seem to recall there was a time that engine instruments were rotated such that a "normal" indication had the needle vertical thus easier to spot anomolous operation during the instrument scan...maybe?
That fire extinguisher on the right side of the
cockpit is a bit troublesome ... note how it
has been mounted so that the release flips
down, which can easily be accidentally done
by anyone climbing into or out of the cockpit.
Maybe it's just me, but I really don't like
loose stuff rolling/flying around in the
cockpit. People can get killed that way. I
know a guy who's radio slid out under
negative G. It smashed him in the face
on the way out and punched a hole in the
canopy
canopy
just curious
- Rank Moderator
Captain_Canuck
On the subject of British airplanes. Some years ago, my father built a replica Spitfire and I thought I would post some pictures here for you all to see. It is powered by a 3.8L Ford V6 out of an SHO with a 2:1 reduction drive that he machined and engineered The structure (wings, spars, fuselage, tail) are all built from wood. Everything on this aircraft was made to exact spec as per the original. Through a family contact at Duxford, he was able to obtain an original Spitfire maintenance manual and replicated almost every part he could. There are even a few original spitfire instruments in the panel. This airplane was made at home in the family garage and at the time was my fathers 10th airplane he either rebuilt or built from scratch. Enjoy!
It seems I will have to post the pics in 2 posts!
Captain_Canuck
A few more pics here
