Refusal of Clearance due to Ice Accumulation?
Changes in Latitudes
I was recently made aware of ATC's option to cancel or refuse a takeoff clearance and order the aircraft to return to the gate/deice pad if visible contamination is observed on the critical surfaces. Does anyone have any insight into the use of this procedure or a formal regulation where this can be found?
I am just curious as to how long this option has been around for and whether or not it even gets exercised.
Cheers...merci.
170 to xray
Re: Refusal of Clearance due to Ice Accumulation?
Post by 170 to xray »
I know a King Air was returned to the ramp last year in yyz. I don't know many of the details though.
scrambled_legs
Post by scrambled_legs »
Who or what made you aware of this? Are you sure it was ATC that was able to refuse the clearance and not TC that could tell us to deny a clearance? I've never heard of it myself and not sure how we'd determine if the wing was contaminated. It's usually hard enough to see if the gear is down, let alone spot a trace of ice on the wing.
invertedattitude
Post by invertedattitude »
scrambled_legs wrote:Who or what made you aware of this? Are you sure it was ATC that was able to refuse the clearance and not TC that could tell us to deny a clearance? I've never heard of it myself and not sure how we'd determine if the wing was contaminated. It's usually hard enough to see if the gear is down, let alone spot a trace of ice on the wing.
I suppose this may pertain to the odd nut who taxis out with 2 feet of wet snow on the wings assuming its going to blow off...
Doc
Post by Doc »
I think it would be a good call. If the tower sees wing contamination from where they sit, a take off would be ill advised. I've never heard FSS inform an aircraft of "ice" on the bird, but I think that would be a good move as well. Some FSS guys are in a pretty good position to observe ice accumulation, and advise pilots.
yrp
Post by yrp »
Or the odd nut who taxis out with the gear up?
(ducking for cover)
invertedattitude
(ducking for cover)
Can't say I've seen that, but I have seen the previous.
