Aerial work: Airborne Survey
If you are a seasoned professional in a certain aviation field and would like to give advice in your area of expertise place a topic in this forum.
Moderators: Sulako, sky's the limit, sepia
chipmunk
Re: Aerial work: Airborne Survey
Post by chipmunk »
Sam300 wrote: Writing the exams soon(hopefully)approx.4800 pic.(looking for something new) Maybe I'll take a road trip and see some operators just to intoduce myself, schedule is open now. If it is slow might be a good chance to meet some people, and chat with them about survey work. Can you point out some good operators to go see? Thanks in advance
P.S. Have a good Thanksgiving weekend!
Wow, well you'd definitely be competitive once things start moving a bit!
Good operators that I would suggest going to see are Aries Aviation in AB and Sander Geophysics & Fugro Airborne Surveys in Ottawa (definitely call ahead for Fugro, the CP/DFO is a pretty busy guy.)
Others may have some more suggestions, but those are some of the better ones that's for sure.
Good luck!
Sam300
Post by Sam300 »
Thanks for the info, I have applied to them but I think I'll try and meet with them and see if something is coming up soon.
TG
Post by TG »
Another topic about Sanders:
viewtopic.php?f=46&t=63890
Dust Devil
Post by Dust Devil »
Keep in mind there is a ton of different survey work and not all of it is low level. There is LIDAR and thermal imaging as well plus others. Most of our LIDAR work takes place 1000m agl and above depending on point density and spec for the job. Geomag isn't the only survey work to be had.
//=S=//
TG
Post by TG »
True, some are even done at FL350 +
But that is another ball game.
Return to “I have a great deal of aviation experience in:”
