doing a group 1 to 4 instrument rating.
Can the flight test be done on the sim?
flight test on sim
- r22captain
Re: flight test on sim
Good question...
Doesn't the sim have to be at least a level D?
Search: "instrument rating flight test"
Result #1: http://www.tc.gc.ca/civilaviation/publi ... 9/menu.htm
Synthetic Flight Training Equipment
General
1. Where a flight test is conducted in a full flight simulator or a flight training device, the examiner must either be trained in the use of the device or must monitor the candidate’s performance while an individual, that has been trained, operates the device in accordance with an agreed-upon script.
2. According to CAR 606.03, any synthetic flight training equipment used for pilot checking or testing, pursuant to Part IV of the Canadian Aviation Regulations, shall have a certificate issued by Transport Canada;
3. A flight training device (FTD) is acceptable for instrument rating renewal flight tests provided that the conditions outlined below are met.
Full Flight Simulator (FFS)
A full-flight simulator used for the Instrument Rating flight test shall be a Level A or higher FFS approved in accordance with the Aeroplane and Rotorcraft Simulator Manual (TP9685). The pilot seats will only be occupied by the required crewmembers. In the case of a single-pilot aeroplane, that would be the candidate only.
Flight Training Device (FTD) (Instrument Rating Renewals only)
A FTD used for an Instrument Rating renewal flight test shall be a minimum level 2 FTD approved in accordance with the Aeroplane and Rotorcraft Simulator Manual (TP9685) with the following enhancements:
1. An enclosed cockpit environment, which will have actuation of controls and switches that replicate those in the aeroplane. May be representative of a single set of aeroplanes;
2. Crew seats shall have sufficient adjustments to allow the occupant to achieve the design eye reference position appropriate to the aeroplane and for the visual system to be installed to align with that eye position;
3. A generic ground handling model that enables representative flare and touch down effects to be produced by the sound and visual systems;
4. Installed systems must simulate the applicable aeroplane system operation. Systems shall be operative to the extent that it shall be possible to perform all normal, abnormal and emergency operations as may be appropriate for the aeroplane during the flight test. Flight and navigation controls, displays and instrumentation must be as set out in CAR 605.18 for IFR operations;
5. The instructor’s station must have the capability to introduce failures on all required systems. Once activated, proper system operation must result from system management by the crew member and not require any further input from the instructor’s controls;
6. Control forces and control travels which respond in the same manner under the same flight conditions as in the aeroplane or set of aeroplanes being simulated;
7. Aerodynamic modeling shall reflect a rolling movement due to yawing;
8. Communication equipment (intercom and air/ground) corresponding to that installed in the replicated aeroplane or set of aeroplanes;
9. Significant cockpit sounds, responding to pilot actions, that correspond to the aeroplane or set of aeroplanes being simulated;
10. A visual system (night/dusk or day), that provides an out-of-the-cockpit view, providing cross-cockpit viewing for the pilot occupying the left seat of a minimum field of view of 150° horizontally and 40° vertically, unless restricted by the type of aeroplane, including adjustable cloud base and visibility; and
11. The visual system need not be collimated. The responses of the visual system and the flight deck instruments to control inputs shall be closely coupled to provide the necessary cues.
