To the administrator:
I request that a permanent forum be established in "employment" where members could state their position (Capt., F/O, Ramp, etc) salary and benefits, work conditions(ie loading own aircraft, hard IFR most of the time etc) and flight times, as well as their aircraft flown and geographic location.
Said forum would have only values and information, not rants.
It would serve as a reference for pilots seeking employment or comparing their salaries with others so employed.
Other aviation sites have this item. I believe that it would be of benefit to our members in Canada and abroad.
There have been threads along this line already posted here. The threads get lost however over time thus indicating the need for a more permanent solution.
I would appreciate an e-mail from you with your thoughts on this matter.
Thank you
TJ ( Late of Winnipeg, now pounding back the brewskys in Brazi
Pay and Benefits
Spaceship 2
- Rank Moderator
That is a good idea TJ. The salary survey is along these lines, however a more finite sounding thing. A forum with this topic would be ongoing. Although I suppose people would start ranting away as we occasionally do
and to Avcanada, is that survey going to be published on this site? And when do you figure it will go up?
thanks
thanks
