YVR METAR
cubonfloats
YVR METAR
Post by cubonfloats »
METAR CYVR 210400Z CCA 10008KT 15SM SCT047 OVC062 M06/M14 A3006 RMK
SF3SC5 PRESFR SLP179=
What does CCA mean?
KAFUFO
Re: YVR METAR
Post by KAFUFO »
They SNAFU'd the Wx the first time they reported it, it means thats the corrected Wx (the Wx didn't change)
tvguru
Re: YVR METAR
Post by tvguru »
First correction
CCB second correction I believe, but I've never seen it.
grimey
Re: YVR METAR
Post by grimey »
tvguru wrote:First correction
Yea, CCB for second, CCC for third, etc. It happens. I've known guys who've had to send out a 4th correction. Another reason for a CCA is if they had to send it out from another station due to network issues. In that case you'd usually see "VIA YWG FIC" or something similar in the remarks though, and it's sent as a correction in case the first one eventually gets through, so that there arn't duplicates.
Invertago
Re: YVR METAR
Post by Invertago »
After around CCZ they change the whole thing to FUBAR I believe.
U/S
Re: YVR METAR
Post by U/S »
Correction Code Alpha
Are we there yet?
BibleMonkey
Re: YVR METAR
Post by BibleMonkey »
In Edmonton they have a guy and a lady who have a continual weather-prediction/description contest.
The boss listened to both their arguments, and finally went with hers.
"SPECI CYEG 151446Z CCA 35009KT 7SM -SN SCT008 BKN018 BKN060 M05/M07 A3019 RMK SF4SC2SC1 VIS HER S SLP261=
Hers
Ok, I made all that up-because I can't find what
HER S
means.
Nordo
Re: YVR METAR
Post by Nordo »
BibleMonkey wrote:...I made all that up-because I can't find what
HER S
means.
Im thinking VIS is 'higher' to the South of the station
TopperHarley
Re: YVR METAR
Post by TopperHarley »
Canucks Can't Advance.
Go Kings!!! :smt040
BibleMonkey
Re: YVR METAR
Nordo wrote:VIS is 'higher' to the South of the station
Thanks, sounds reasonable.
I don't think that one is in an abbreviation explanation guide.
I looked (only ) a little more;
maybe they forgot the the "I" before e in hier.
This 8 mb file , chapter 21 (Aware, the atmosphere, weather, and flying )
http://www.ec.gc.ca/Publications/defaul ... 262642C7B2
from
http://www.ec.gc.ca/meteo-weather/defau ... BAE7EC63F7
has 'higher" as
HIER
or Navcanada has some differences with Environment Canada.
Jonathan
Re: YVR METAR
Post by Jonathan »
No, the appropriate abbreviation is HIER.
