Carson Air
Max_Power
Carson Air
Post by Max_Power »
Could anyone tell me about Carson Air and if they're going to be doing any hiring in YVR or YYC any tme soon. As well as:
Pay
Upgrade times
Schedule
Benefits
Any info would be appreciated.
gianthammer
Re: Carson Air
Post by gianthammer »
In order;
Criminal
If you :prayer: to the CP
Depend on the Base; YYC guys get it Easy, YVR guys take it in the A$$(and not just because they are canuck fans)
Non Existant
Hope that Helps
B-rad
Re: Carson Air
Post by B-rad »
DP
not quite the same as:
DVDA
My ambition is to live forever - so far, so good!
B-rad
Re: Carson Air
Post by B-rad »
I don't think you mentioned anything about the hiring... so your answers confused me at first.. I thought they were in order
Max_Power
Re: Carson Air
Post by Max_Power »
Thanks for the info. Does anyone know if they are indeed hiring?
Re: Carson Air
Post by sky's the limit »
You should call the Owner, he's a great guy to chat with... or not.
flyboy114
Re: Carson Air
Post by flyboy114 »
there are other threads here that deal with some of the questions.....
schedule is mon-fri for the cargo side, both in vr and yc. medevacs are different 4+4/5+5 etc.
Not much movement at the moment, so unlikely to be hiring anytime soon. That's for both the cargo and medevac side. Minimums are 1000 TT + 500 multi. And you need to be up to date IFR-wise. You fly 80 + hrs a month normally; no autopilot. Hard work, pay is low, but the flying is good and you will definately get the skills in a Metro.
mattas350
Re: Carson Air
Post by mattas350 »
Thanks for the info :D whats usually involved (requirements wise) in getting directly into the medevac side? Thanks.
brownbear
Re: Carson Air
Post by brownbear »
What I find odd is pilots ask about benefits, schedule and pay before other things...
I had the opportunity to work on one of their planes and noticed they kept them clean and well maintained. It was not a shabby plane. The engine was clean and tidy... these things stand out to an AME. Where opposed to a Jazz plane I saw up close that looked like a serious turd. With thousands or so of smoking rivets and old stains.
For time builders, there is something to be said about just being able to strap into something that isn't unsafe or shitty.
Now that said, it was a brief moment I saw this plane, and the pilots were very happy with maintenance.
wallypilot
Re: Carson Air
Post by wallypilot »
mattas350 wrote:Thanks for the info :D whats usually involved (requirements wise) in getting directly into the medevac side? Thanks.
You either go into the cargo side or the medevac side...very few have moved between, although it has happened a couple times.
It's cheaper to hire an outsider and train 1 pilot, than transfer internally and pay for 2 initial courses. Right or wrong, that's the reality.
As far as I know right now, there aren't vacancies on the medevac side, but if there were, you'd be looking at around 1500 to get in, with some decent IFR experience in there. BCAS requirements. There's a bit of wiggle room there, as BCAS will give conditional waivers if no qualified crew are available, and a position needs to be filled.
teamsf
Re: Carson Air
Post by teamsf »
Typical. Ask these questions:
Pay
Upgrade times
Schedule
Benefits
Get these answers:
Criminal
If you to the CP
Non Existant
Then follow it up with this:
From what I've heard the bond is big, the pay is horrid, the sched is aweful... But I have only heard that from friends of mine who have worked there. They fly a lot, so you could build time there, but just don't expect to make enough money to pay your bond off when you leave.
ScudRunner
Re: Carson Air
Post by ScudRunner »
Benefits
YOU GET TO FLY A METRO!!!!!!!
chowda
Re: Carson Air
Post by chowda »
From a strictly maintenance perspective, when I was there I found it a good operation, with no one from management ever demanding anything but a legal, airworthy aircraft. Was a good crew of guys in yvr, with one notable exception.
In short, have no worries on the mechanical side.
WhatThe?
Re: Carson Air
Post by WhatThe? »
Fair enough!
Good luck, we all make choices, just don't be mad at Carson or the CP if YOU make that choice.
Edited for stupidity!
B-rad
Re: Carson Air
Post by B-rad »
WhatThe? wrote:Any company with 17 pages of CADORS on the TC website....
CADORS, for the most part, Aren't worth much to judge a pilot or a company on. And besides, if you go to fly for them, doesn't mean you have to be adding to the CADORS.
Re: Carson Air
teamsf
Re: Carson Air
Post by teamsf »
Cadors aside it's still not an ideal place to work. Horrible schedule, worse pay, and no benefits. Why is the compensation bad? Because the turn over is high, why is the turn over high? Because the compensation is bad... Vicious cycle we have here don't we? And it will only continue when people know the compensation is bad but still ask "anyone know if they're hiring?" There is always someone who will work for free, and in an effort to get a head they inadvertently devalue our entire occupation. Some can justify it by saying they're "paying my dues", but the truth is you're not. There are a few entry level gigs that actually will pay you enough money to live where you work, these are the places that need to be promoted on this forum.
joe to go
Re: Carson Air
Post by joe to go »
When i worked there, about 3 years ago (for 6+ years) there was profit sharing as well as health and dental benefits. And there are at least 20 ex Carson guys at WestJet now. From number 50ish in the pilot list, up to the 900's.
Return to “Employment Forum”
