Private OC - help
baron_dude
Private OC - help
Post by baron_dude »
Hi all,
It seems like we will have to bite the bullet and set up an OC for private operations with a Turbine. Any help or input would be appreciated. Where to start especially. Thanks in advance
Bushav8er
Re: Private OC - help
Post by Bushav8er »
Mach .28
Post by Mach .28 »
604 operators have been certified and regulated by te CBAA sine 2003.
You will be required to prove operational control similar to a 70x op.
Some things are quite different such as developing a fatigue management program etc.
Check out www.cbaa.ca and check the POC section
If you have ever set up a AOC it is similiar to that
Hornblower
Post by Hornblower »
Should be no problem, ... just contact the CBAA and they will sell you the full package.
Essentially you just buy it from them. Easy as pie, ... just takes money.
