Page 1 of 1
CPL(H) to fixed wing
Posted: Wed May 20, 2009 5:04 pm
by lfried
if i currently hold a CPL(H), can i use some of those hours to convert to an airplane license? PPL or CPL?
Re: CPL(H) to fixed wing
Posted: Wed May 20, 2009 5:51 pm
by Adam Oke
Yes. Scroll through the ref. below. Here are some quotes regarding CPL(A)
(i) An applicant who holds a Commercial Pilot Licence ‑ Helicopter or higher, shall, when applying for the issue of a Commercial Pilot Licence — Aeroplane, be credited with 20 hours of the 80 hour ground school instruction requirement.
(amended 2006/12/14; previous version)
(ii) An applicant who holds a Commercial Pilot Licence - Helicopter or higher, shall, in lieu of completing the written examination Commercial Pilot - Aeroplane (CPAER), obtain a minimum of 60% in the written examination Commercial Pilot Licence (Aeroplane) - Alternate Category (CARAC).
(amended 1999/03/01; previous version)
(i) Commercial Pilot Licence - Helicopter
If an applicant holds a Commercial Pilot Licence ‑ Helicopter, the 200 hours total flight time in aeroplanes required by subparagraph (4)(a)(i) is considered to have been met if the applicant has completed a minimum of 100 hours pilot flight time in aeroplanes, including the 65 hours experience required by subparagraph (4)(a)(ii). In this case, it is not necessary to obtain a Private Pilot Licence — Aeroplane prior to obtaining the Commercial Pilot Licence — Aeroplane.
Ref: http://www.tc.gc.ca/CivilAviation/Regse ... htm#421_30
Posted: Thu May 21, 2009 10:28 am
by lfried
perfect thanks, do you take a total of flight time between both rotor-craft and fixed wing? or are the 2 times separated when referred to in a resume?
Posted: Thu May 21, 2009 2:04 pm
by Adam Oke
I would put your total time as everything, then break it down respectively on the resume.
TT
Fixed
Fling-Wing
Glider
Ultralight
etc.
