Beaver Tips
tzu
Re: Beaver Tips
Post by tzu »
Crosswind tips?
Climb flap... no flap... extra power..
Any other techniques by the seasoned drivers?
phillyfan
Re: Beaver Tips
Post by phillyfan »
You can try playing with the flaps but the redline is there for a reason.
tzu
Re: Beaver Tips
Post by tzu »
phillyfan wrote:You can try playing with the flaps but the redline is there for a reason.
:smt017
phillyfan
Re: Beaver Tips
Post by phillyfan »
More power as in more then 36.5 in?
adhc2
Re: Beaver Tips
Post by adhc2 »
As per Beaver manual Max takeoff power is 36.5" & 2300 rpm reduce as soon as possible to (max 1 min) Max continuous 33.5" and 2200 rpm. Further reduce numbers by 2% per 11C below standard ambient temp of 20 C .Max continuous is of course max and normal ops reduce to 30" .Some will fly heavy with just a small notch of flap to enable a lower nose attitude, never the less you may be using flap at above published limits in doing so. This may put additional load on flap system overtime leading to premature wear but I suspect not significantly. It may give you a little more speed and therefore better cooling on those hot and heavy days. just remember they will haul a serious load but when heavy it performs much more lethargicly and therefore exersize appropriate caution and diligence.
mr.jinks
Re: Beaver Tips
Post by mr.jinks »
do people actually set the throttle linkage up to stop at 36.5 on a standard day? ... every one i have seen will go way past if firewalled.
angry inch
Re: Beaver Tips
Post by angry inch »
No... That would really suck if you took off at sea level & went into a lake at 5000'...
buck82
Re: Beaver Tips
Post by buck82 »
Or even had a hot day at sea level...
Wildernesspilot
Re: Beaver Tips
Post by Wildernesspilot »
I fly the Beaver in open ocean conditions and although rarely see calm water I'm finding it hard to get a good glassy water configuration, any advice?
Re: Beaver Tips
70 mph with climb flap seems to ring a bell. You needed about 20 inches of MP, and that gave you around 300 fpm rate of descent. Try that and see if it works. When you get into ground effect the airplane will flatten itself out a little. It's been 40 years since I flew one, so I could be full of shite on that. :)
cdnpilot77
Re: Beaver Tips
Post by cdnpilot77 »
Can anyone post some tips on flying the mighty beav with wheel-skis
Wildernesspilot
Re: Beaver Tips
Siddley Hawker thanks for that, I will try it tomorrow and let you know.
Slats
Re: Beaver Tips
Post by Slats »
cdnpilot77 wrote:Can anyone post some tips on flying the mighty beav with wheel-skis
I found it even easier to fly on straight wheels than on floats, if that's possible. Not sure about skis though. Had a great deal of difficulty getting the tailwheel to caster (sp?) but assumed it was due to the specific aircraft and usually operating on slippery hard-packed snow conditions.
For glassy water, I never really changed my usual configuration at all, just used power as necessary and found it always worked beautifully. Always found the Beav easier to land glassy water than Cessnas.
The airplane is truly a dream to fly when operated within its limitations for its intended purpose.
Re: Beaver Tips
xsbank wrote:What I know: detonation is the uncontrolled burn of the fuel charge in the cylinder, usually BTDC. Can cause serious engine damage. Overly-lean mixtures, cylinder head temps too hot, manifold pressure too high, ignition timed incorrectly etc.
WAG: on one magneto, perhaps the charge is not completely burned or the local temperatures are too high and when the next fuel charge is introduced it combusts spontaneously? Remember that above a certain throttle setting, (don't remember what that is - help me out here) excess fuel is introduced to keep the cylinder heads cool, perhaps it is this extra charge, compressed to a large degree by the supercharger, improperly controlled by the loss of half the ignition that causes the detonation?
The tetraethyl lead they used to add was to prevent some detonation and have a controlled flame front. That has been largely removed now. Also remember that the fuel is not supposed to ever 'explode' even at the correct time.
Rowdy, you have lots of "supercharger" experience, comments?
XS, you're pretty spot on there.. Look at where the plugs are situated.. they arent in a central location in the cylinder head. They are in fore and aft positions.. So you're right, getting an incomplete burn which could cause carbon buildup or perhaps some of the unburnt fuel to sit on or around a valve or imperfection in the case or casting or even on the piston crown and ignite during another incorrect time in the cycle. Now you're also going outside of the norm for the internal combustion engine and forcing compressed air and fuel into this cycle.. I know from experience at high boost levels that the single (factory) ignition on a couple of the turbo car motors I've run would actually run out of jam so to speak. You'd be blowing out that spark and not getting the correct ignition of the fuel.. I'll see if I can dig up some old pics of the burnt valves and lifted crown from such an experience.. Albeit that was a few seconds of detonation at high boost levels (30psi). Like the factory book notes.. I'm sure at the lower boost levels that a 985 is spinning in cruise wouldnt cause instantaneous damage, but prolonged running would build up carbon deposits on valves and the piston head/crown. And like tired of the ground said.. act like a glow plug and retain enough heat to cause ignition on the compression stroke. Now dont forget.. theres a lot more heat with all that forced air already..
The lead was (and still is in 100LL) there for more than just a reduction in detonation by increasing the octane rating. R+M/2. It was also there to aide in forming a seal (read buildup) on the valve seats as well. You'll remember that a lot of vehicles that used to run and were designed for leaded fuels needed to have hardened valve seats installed in the heads or be run with a lead additive. I'm not THAT knowledged on the internals of the 985.. but I'm guessing with it's STC approval for the use of Mogas and 80/87 that they already have hardened seats or they were added at some point. Any of the knowledgeable AME's care to comment on whats involved with the STC or if I'm way off base here?
Re: Beaver Tips
I can remember when we ran the small Pratts on 91/98. When that was phased out for 80/87 the power settings remained the same. One year we ran out of 80/87 on the coast and used 100/130 for the last few weeks of the ski season. I seem to recall that for every hour in cruise at 28 and 18 we were supposed to apply METO power for one minute. That really didn't amount to much because most of our hops were less than 30 minutes anyway.
Somebody asked about ski tips. I don't have much ski time on the Beaver, but I've flown both Federal and deHavilland skis. There's something to be said for both types. In soft snow the Federals are better because of the larger footprint. Downside is you are either full skis or full wheels. The deHavs you can select half and half to use a little brake if the conditions warrant. On skis, always do wheel landings with the tail low. The airplane is fairly stiff-legged in drifts, here again the Federals are better because the wheel sits on top of the ski and will absorb some of the impact. Stay out of slush with either type. Unless you're sporting the skis that Fecteau used on theirs. They hung Otter wheel replacement skis on their Beavers and could pretty near land on clear water as long as you had a decent place to park. :D
Wp, I hope you never got yourself into a peck of trouble with that glassy water procedure. Like I said, it's been awhile. :)
Wildernesspilot
Re: Beaver Tips
HS
Your technique seems to work pretty good, like I say down here on the great Barrier reef we don't really see glassy water but we do get allot of days with very poor vis so a gentle approach and slow let down onto the water is in order. I found at 19 inches and climb flap I was getting about 300ft a min and maintaining around 70kts, cheers.
cdnpilot77
Re: Beaver Tips
-2 threw me it's first curveball this morning with a fuel pump failure. Gotta love the wobble pump all the way home. Getting fixed tomorrow morning and hopefully back in the air tomorrow aft.
Thank you all for the tips in this thread, they have been remarkably helpful with my newness to this airplane and have been put to use with each flight!
CP77
skybaron
Re: Beaver Tips
Post by skybaron »
Stall Characteristics
http://dsp-psd.pwgsc.gc.ca/collection_2 ... 01-47E.pdf
in brief:
(ATS) flight test report of that activity indicates that with a forward CG, the
stall characteristics of the aircraft were acceptable. However, with an aft CG
and with power on, departures of 60 degrees of roll, 30 to 40 degrees of yaw,
and 30 degrees of pitch were reported as being common during these flight
tests. With the flaps selected to the “climb”, “take-off”, and “landing”
positions, the ATS flight test report indicates that the ailerons and rudder
were effective up to the point of the stall but were not adequate to control
the violent roll and yaw once the stall occurred. A positive elevator
movement was required to recover from the stalled condition before the
aircraft began to spin.
Interesting read, especially seeing as the -2 is so easily loaded aft CofG.
(Holiday/weekend sched runs on the coast seems to ring a bell)
Above 80mph does the trick, but as Beaver Bob mentioned - exercise caution with steep angles of bank.
Re: Beaver Tips
Anyone care to point me to some more info on the Baron kits? with the wing angle change.. is there any change to the flap settings above and beyond the obvious?
beaverbob
Re: Beaver Tips
Post by beaverbob »
Rowdy wrote:Anyone care to point me to some more info on the Baron kits? with the wing angle change.. is there any change to the flap settings above and beyond the obvious?
Hi Rowdy,
Use the same flap settings as befor, except not helpful or required in cruise, Visibilty forward is better. I think top cylinder cooling could be better.
Most important, the stall characteristics are much improved over the original non-Baron Beaver,
Bob
