Am I correct in assuming that single engine aircraft that can't maintain level flight after losing an engine are not allowed to fly more than 100nm / 30 minutes from a suitable landing field UNLESS they have life rafts? So in other words, if they have life rafts, single engine aircraft can fly more than 100nm away from the shoreline?602.63 (1) No person shall operate over water a single-engined aeroplane, or a multi-engined aeroplane that is unable to maintain flight with any engine failed, at more than 100 nautical miles, or the distance that can be covered in 30 minutes of flight at the cruising speed filed in the flight plan or flight itinerary, whichever distance is the lesser, from a suitable emergency landing site unless life rafts are carried on board and are sufficient in total rated capacity to accommodate all of the persons on board.
How about multi engine airplanes? Am I correct in assuming that multi engine aircraft that can't maintain level flight after losing any engine are not allowed to fly more than 100nm / 30 min from a suitable landing field UNLESS they have life rafts?
If what I said is correct, then how on earth does a single engine C172 manage to cover 100nm with a failed engine? Essentially transport is saying that it's okay to operate a C172 up to 100nm away from the shoreline with no life rafts... The C172 wouldn't even qualify under the 30 minute rule either because operating a c172 with a failed engine at cruise speed is maybe a 10-12 nm glide if you started at the absolute ceiling... am I wrong ? I'd be glad to be corrected. Maybe I'm comprehending the regulation incorrectly.
Am I correct in understanding that unless you have life rafts, even though you can maintain level flight after losing an engine, you cannot fly more than 200nm / 60 minutes from a suitable landing field?(2) Subject to subsection (3), no person shall operate over water a multi-engined aeroplane that is able to maintain flight with any engine failed at more than 200 nautical miles, or the distance that can be covered in 60 minutes of flight at the cruising speed filed in the flight plan or flight itinerary, whichever distance is the lesser, from a suitable emergency landing site unless life rafts are carried on board and are sufficient in total rated capacity to accommodate all of the persons on board.
So only if the transport plane is at any point more than 400nm / 120min away from a suitable landing site do they LEGALLY have the need to have life rafts ? Would ETOPS defeat this regulation?(3) A person may operate over water a transport category aircraft that is an aeroplane, at up to 400 nautical miles, or the distance that can be covered in 120 minutes of flight at the cruising speed filed in the flight plan or flight itinerary, whichever distance is the lesser, from a suitable emergency landing site without the life rafts referred to in subsection (2) being carried on board.
Thanks for the help !
