Tailwind Takeoff.....your 2 cents
Kosiw
Post by Kosiw »
In what position do you hold the ailerons, if you had to takeoff in a quartering tailwind? (only for arguements sake, and not interested in performance issues...), interested in all aircraft types.
K
Gravity always wins
flyinthebug
Re: Tailwind Takeoff.....your 2 cents
Post by flyinthebug »
If its a quartering tailwind..deflect your ailerons into wind. Quartering left, slight aileron left..opposite for right quartering. Has worked from Cessna, to Beaver, to King Airs and Hos for me. I MUST add an addendum that I very rarely take off with a tailwind. All other components need to be right for me to opt for a tailwind takeoff. Sometimes on the coast there is no other choice. Just beware, they are dangerous under the wrong circumstances.
pilotbc69
Post by pilotbc69 »
Agreed with above...but with a Chopper Reid accent and lots of ehhhhh fakin's before each sentence.
Ray-Ban
Post by Ray-Ban »
pilotbc69 wrote:Agreed with above...but with a Chopper Reid accent and lots of ehhhhh fakin's before each sentence.
Sorry to jack this thread, but this is the best safety briefing. 8)
Warning: NSFW
http://www.break.com/usercontent/2009/1 ... 50506.html
Reason: to add NSFW
Post by North Shore »
Happiness is V1 at Thompson!
DHC3Rwannafly
Post by DHC3Rwannafly »
Think about it... if your taking off with a tailwind, its probably no more than 10-15 kts.....so as soon as your ASI reads 20, well there's no tailwind on your controls......
paydaymayday
Post by paydaymayday »
Think about it even harder, DHC. How does your ASI read your speed? And what speed does it measure? Would it really need to show 20 in order to prove you have no tailwind?
DHC3Rwannafly wrote:Think about it... if your taking off into a tailwind, its probably no more than 10-15 kts.....so as soon as your ASI reads 20, well theres no tailwind on your controls......
DHC3Rwannafly
No but the airplane can't tell the difference between being parked and having a 20knot headwind, reading 20 on the asi, or whether its moving forward with a tailwind and reading 20kts. It's still 20 kts on the head.
paydaymayday
Yes, and you wouldn't have to wait for your ASI to do anything but begin to move.
RVgrin
Post by RVgrin »
DHC3Rwannafly does need to think about the ASI a little harder, but he (almost) made the point that I was going to make: whatever taxi/start-of-take-off-run control inputs you start with need to be relaxed as you speed up.
OhKiE DoHkIe
Post by OhKiE DoHkIe »
DHC3Rwannafly wrote:Think about it... if your taking off with a tailwind, its probably no more than 10-15 kts.....so as soon as your ASI reads 20, well there's no tailwind on your controls......
:smt104
I think that logic also works best in a A380 in the performance chapters under ASDA TODA sections of that aircrafts' AFM.
There are a lot of young eyes reading this forum...I'd hate to see your advice be taken seriously. 'jus sayin' :)
"When your dreams turn to dust, vacuum."
Hedley
Post by Hedley »
With a propeller on the front of the fuselage, you don't even
have to wait for the ASI to move, with respect to the elevator
(and rudder) - the prop slipstream takes care of that!
If I apply brakes and some power, I don't even need any
forward stick to raise the tail, when I am still stopped -
all I need is neutral stick - just let go of it! Clearly any
tailwind component is irrelevant to the elevator.
I have done airshows in Central America where we have
done head-on takeoffs and landings, and I had a 20 knot
tailwind for both. No biggie.
Liquid Charlie
Post by Liquid Charlie »
Downwind is best on floats -- waves are not as sharp :mrgreen:
ACTPA :kriz:
