Is it any ATPL check ride guides?
YYC
Post by YYC »
Hi guys!
Is it any ATPL flight test guides,like TP 9939E for instrument and TP 13462E for commercial ?
Many thanks! :shock:
Teeg
Re: Is it any ATPL check ride guides?
Post by Teeg »
there is not flight test to get your ATPL, rather experience...
http://www.tc.gc.ca/civilaviation/regse ... htm#421_34
YYC
Post by YYC »
Thanks,so only this skill reguirements:
(5) Skill
(a) Within the 12 months preceding the date of application for the licence, an applicant shall demonstrate in a multi-engined aeroplane with no central thrust configuration and fitted with instruments and equipment suitable for IFR flight in controlled airspace, familiarity with and the ability:
(amended 1999/03/01; previous version)
(i) to perform both normal and emergency flight procedures and manoeuvres appropriate to the aeroplane in which the flight test is conducted; and
(ii) to execute all manoeuvres and procedures set forth in Division XIV for issue of a Group 1 instrument rating.
Teeg
Post by Teeg »
Correct, but just to ensure i answer the question correctly:
you must write the ATPL exams SAMRA AND SARON. You must hold a Group 1 instrument rating.
you will get your ATPL signed off with the following times:
(4) Experience
An applicant shall have met the training requirements for the issue of a Commercial Pilot Licence - Aeroplane that is not restricted to daylight flying and completed a minimum of 1500 hours total flight time of which a minimum of 900 hours shall have been completed in aeroplanes. The total flight time shall include a minimum of:
(amended 2000/09/01; previous version)
(a) 250 hours pilot-in-command flight time in aeroplanes which shall include where applicable, a maximum of 100 hours pilot-in-command under supervision flight time completed in accordance with Section 421.11. The pilot-in-command and/or pilot-in-command under supervision flight time shall include a minimum of 100 hours cross-country flight time of which a minimum of 25 hours shall have been by night;
(b) 100 hours night flight time as pilot-in-command or as co-pilot of which a minimum of 30 hours shall have been acquired in aeroplanes;
(c) 100 additional hours cross-country flight time as pilot-in-command or 200 hours as co-pilot or any combination thereof, with flight time calculated in accordance with section 421.10. Flight time as pilot-in-command may be part of the 250 hours pilot-in-command flight time specified in paragraph (a); and
(amended 2005/12/01; previous version)
(d) 75 hours instrument flight time of which a maximum of 25 hours may have been acquired in approved instrument ground trainers and a maximum of 35 hours may have been acquired in helicopters. Instrument ground time shall not be applied toward the total 1500 hour flight time requirement.
