DME Arc
lownslow
DME Arc
Post by lownslow »
Alright, this is embarrassing and to be honest I was hesitant to post but I truly suck at flying DME arcs. Does anyone have any advise on how to improve or perhaps different techniques to use?
LnS.
Shiny Side Up
Re: DME Arc
Post by Shiny Side Up »
What specifically do you have problems with? I find that people usually have problems with them if their VOR situational picture is poor to begin with. It is also far easier to accomplish if you have 2 VORs set up during it, they're a bit of a pain if you only have one.
KK7
Re: DME Arc
Post by KK7 »
As SSU said, we need a bit more info about what issues you have before we can help without teaching it all from scratch. It also helps if we know what equipment you're using, like 1 or 2 VORs, and if you have an RMI it makes them incredibly easier.
I suggest practicing in a sim on autopilot to start with, even if it's on your own computer (although I don't know what sim software is good these days). They are a time consuming procedure and cost a lot of money to practice in the airplane, or even in a sim at a school that you rent. But luckily you can practice them at home, get a good understanding on how to work them in different situations, and really just start by focusing on procedure with the autopilot on, rather than worrying about keeping the sim straight and level. Once you got them, then you can hand fly them, then finally if you have one near where you fly, go out and fly one.
Re: DME Arc
If you have an RMI with a co-located VOR (or VORTAC), or an ADF with a co-located NDB, it is very easy. Just keep the needle on your wingtip and monitor the readout. Memorize your formula for intercepting the arc. Some people find it easy to fly 'sectors', changing heading every ten or twenty degrees. I always preferred to let the aircraft drift slightly in the direction of the arc.
I don't believe there are any arcs published without a VOR or NDB, since bearings/radials are also what defines the arc plus the lead bearing/radial to turn to intercept. I can see where it would be very hard with a standard CDI to keep situational awareness though.
Re: DME Arc
As pie said if you have a 2 needle RMI than you just keep the turning to keep the needle at a 90 deg relative bearing. Since most training aircraft just have a HSI and a VOR head this method is not an option. I have tried all the fancy formulas and OBS knob twiddling, but could never get the practice to match the theory, so I finally just ended up using the "Yay" method
. Set the No 2 VOR track bar to lead radial and continue to track towards the VOR with the number HSI When you are 1/2 mile from the DME arc distance (for the average light twin) turn 90 degrees in the direction of the arc and reset the HSI track bar to the inbound track of the approach. The DME distance will be at or close to the published arc distance. Fly on until the DME increases by .3 and then turn in 10 degrees wait until the distance stops decreasing and then starts to increase again and turn in another 10 degrees. In other words "Yay" the amount of turn based on whether the DME is increasing or decreasing. When you get to the lead radial turn to the procedure turn in bound heading (ie 45 deg) until intercepting the final approach track
lownslow
Re: DME Arc
Post by lownslow »
Thanks for all the input so far. As for the nav equipment I have, there's two NAV/COMMs; ADF; a DME (duh); and a GPS, which is probably where my problems started. All along I've been flying arcs on the GPS, which is easy to the point of boring and I've realized I need to do it the old school way if I'm to take myself seriously.
Shiny Side Up/KK7, I think situational awareness might be a part of my problem. Typically I can keep a very good 'air picture' of what's going on in IMC or under the hood but I think I'm over thinking the whole procedure when it comes to flying the arc. I'm not necessarily getting lost (this is while simming, btw) but either getting too far behind or maybe too far ahead and ending up way off the arc, or at least far enough that I'm not happy.
BPF, I'm going to try out the 'yay' method in the next couple days. Simple is good.
LnS.
rjonno
Re: DME Arc
Post by rjonno »
In my experience DME arcs are one of the few things out there that are actually made more difficult by using GPS. assuming you have an HSI/RMI:
-Figure out how early you should start the rate 1 turn to intercept the arc, obviously this will vary depending on what aircraft you are flying/at what speed.
-Once your established on the arc, let your RMI needle fall about 10* behind your wing, then make a turn into the arc, bringing the needle 10 degrees ahead of your wing. Then let the needle fall to 10* behind you again. Continue this staying within a couple 10ths of a mile of the published arc. If you're too close in, let the needle fall more than 10* behind your wing. If you're too far out, turn into the arc more than 10* to correct.
-As soon as you're established on the arc, set your HSI to the inbound course for the approach
-Every few seconds I like to just mentally review the published lead-radial where i'm going to start the turn on to the inbound course for the approach.
Presumably this will work the same way using a fixed card ADF with an NDB co-located at the DME. Though you're better off with an RMI. Once you get the hang of doing it in 20* sectors like I described above, its easy to just establish a couple degrees of bank and fly the DME arc right around the circle nice and smooth
Gannet167
Re: DME Arc
Post by Gannet167 »
What do you mean "too far behind" or "too far ahead" ? Once you're on the arc, fly straight and level holding an accurate heading. When the needle is 10 degrees behind your wingtip, alter your heading by 20 degrees to put it 10 degrees ahead of your wing tip. It's mindlessly easy this way.
Once you're good with that, do it with winds. If the wind is pushing you towards the station, put the needle 5 degrees head of the wing tip and wait for it to be 15 degrees behind the wing tip before changing heading again. Of course the wind component changes as you go around the station. If the winds are strong, put the needle on the wing tip and then wait for it to be 20 degrees behind.
Re: DME Arc
lownslow said he doesn't have an RMI.......
Gannet167
Re: DME Arc
Post by Gannet167 »
I'm not sure how you'd fly an arc without an RMI, I guess you could continually be adjusting your VOR CDI needle. This seems almost ridiculous to me. I'd ask for vectors at that point or use my GPS to go somewhere direct. Get an RMI.
lownslow
Re: DME Arc
Post by lownslow »
Gannet167 wrote:I'm not sure how you'd fly an arc without an RMI, I guess you could continually be adjusting your VOR CDI needle. This seems almost ridiculous to me. I'd ask for vectors at that point or use my GPS to go somewhere direct. Get an RMI.
Not every airplane has an RMI, not every approach has vectors available. Luckily my GPS is capable of guiding me through any published arc but as I said, I want to be able to use ALL the equipment on board the airplane.
Back to BPF's method, here's what I'm getting:
Obviously I'll be coming up on the arc at 90* to the arc itself. At this point I'm tracking inbound to the navaid, but this part I knew. Sounds like about 15-20 seconds before I reach the arc I want to turn 90 degrees and fly that heading until I'm at the arc DME distance +.3 or so then turn 10*. Repeat as necessary until I'm at my lead radial or final approach course. If I'm understanding correctly, while I'm flying the arc itself I don't know or care exactly what radial I'm on, only that I'm not yet at my lead radial.
Am I close?
LnS.
Re: DME Arc
Am I close?
LnS.
Yup don't worry about the radial you are passing just Yay the DME distance....
KK7
Re: DME Arc
Post by KK7 »
I'm not going to add much since BPF's method is spot on.
But I do want to throw out there that I am quite pleased that this is being practiced. Although DME arcs aren't used very often in N. America, overseas some places have nothing but. In my experience particularly the Middle East, unless flying into a major centre like Jeddah, there is no radar environment and one has to fly an arc to transition to the approach. I flew with quite a few people who had never even flown an arc before, despite holding an instrument rating.
Gannet167
Re: DME Arc
Post by Gannet167 »
If you want to be really nerdy about it, you can calculate your lead DME to turn onto the arc. For a rate 1 turn onto the arc, I believe it's 1/2 your TAS, which you can get by multiplying your altitude in 1000's by 4 above 10,000', or by 3 if under 200 kts.
So at 12,000' and 220 kts, you'd multiply 12 x 4 and add that to IAS to get 268 kts TAS. Plus or minus a wind component. Without wind, start your turn at 2.7 DME ahead of the arcing DME. For a 12 DME arc, that'd be 14.7 DME. All this is quite academic and useless if you know how to WAG it (wild ass guess). I think I'm remembering that right.
I suppose you can Yay your arc, but unless you're going quite slow and the winds are light, to me this is a recipe for getting confused and off the arc. An RMI is the clear way to go. If you don't have one, I wouldn't feel bad about not flying perfect arcs - and in real life I'd look for a better way to transition onto the approach with the kit I have.
Dagwood
Re: DME Arc
Post by Dagwood »
What do you mean by "Yay" an arc? I haven't heard that terminology before...
Doc
Re: DME Arc
Post by Doc »
I never do them. Keeps it simple.
You could write a book about it. Some have. See above.
Keep the fix to your left or right, maintain the proper DME + about .2 miles, and keep it there. You can't help turning. Then about 10 or so degrees from the inbound....in you go. That's it. No smoke and mirrors. KISS
SuperchargedRS
Re: DME Arc
Post by SuperchargedRS »
I use my range and ground speed, keep a steady turn with a GS of 0 and your shooting a spot on arc. range increases a little tighten it up slightly.
Re: DME Arc
Dagwood wrote:What do you mean by "Yay" an arc? I haven't heard that terminology before...
Yay = Use judgement and situational awareness to manage a procedure. So in this case when the DME is increasing you turn in and when it is steady or decreasing you hold your heading. The rate and magnitude of the DME range changes determine how/when to turn in.
Many flight schools use formulas to decide when to turn and and a complicated procedure of re-centering the OBS to stay on the arc. Personally I have found they brief well in the class room but don't work very well in the air. My personal feeling is that the time and brain cells used in doing mathematical formulas and constantly twiddling the OBS knob is better spent flying the airplane and maintaining situational awareness
toelessjoe
Re: DME Arc
Post by toelessjoe »
I have a procedure I follow religiously whenever I feel the need to do a DME arc approach that goes like this:
1) After convincing some silly bugger at ATC that I simply MUST do an approach that takes up shit loads of time and airspace for no apparent reason I proceed to grab the nearest heavy object and beat myself thoroughly about the head and shoulder area, paying particular attention to the frontal lobe.
2) Upon regaining my faculties, I then plug the stupid thing into the GPS and let the autopilot fly it.
3) Once set up, I request fellatio from the f/o. You know, since we apparently now have some time to kill.
Silly wabbit, arcs are for kids!
- Toeless. :lol:
Gannet167
Re: DME Arc
Post by Gannet167 »
Agreed, if you don't absolutely have to do one, why would you? In the case of training though, it's necessary and a good thing to know how to do and practice. This "yay" thing must be in a relatively slow aircraft. It's not practical in anything that moves quick.
Re: DME Arc
Gannet167 wrote: This "yay" thing must be in a relatively slow aircraft. It's not practical in anything that moves quick.
You are correct and as I specified in my original post it was for IFR training aircraft which will down in likely be down in the 120 kt range when flying the arc. I also made the assumption that a guy with the handle "low and slow" wasn't flying "anything that moves quick". In addition faster movers are going to have an RMI and most probably an approach approved GPS or FMS which along with the RMI are going to become the primary aid in flying the arc.
KK7
Re: DME Arc
Post by KK7 »
If you're going to stay flying in N. America, I'd say you could probably just get away with knowing how to do one in your training, and avoid ever doing the damn time consuming procedure, there are usually plenty of other and better options IMO.
HOWEVER, if you ever plan to fly somewhere outside the continent, you will need to know how to do one, and you will have to use that skill. Often times I've heard aircraft get the clearance from ATC to conduct the DME arc to transition to an ILS (in a non-radar environment, or a radar environment where the local controllers don't really know how to use it, and this latter case is surprisingly common). Then you hear the pilot either angry that he got such a clearance, or a little nervous having to do one, request some other method like an RNAV approach or something else. This is followed by silence, then eventually "Negative, XXXX cleared the DME arc ILS XX". I've also noticed a lot of controlled airport sin Africa have RNAV approaches that you'll never get cleared to do, most commonly because the controllers are not trained for these approaches. If you ever mention a waypoint on an RNAV approach, they are very confused and have no idea what you're talking about.
If you're looking to save time though, and have a GPS, sometimes you can request direct to the IAF for the approach rather than doing the whole arc, so long as there isn't any other traffic around.
The rare times I get to fly back home in Canada, I am always incredibly super uber impressed with the ATC we have in Canada. Pilots don't know how good we have it.
lownslow
Re: DME Arc
Post by lownslow »
Thanks again to all for their input. It's been interesting to see that nobody really cares about their arc prowess, here I thought I was alone in not mastering them. Like I said prior, it's a part of aviation and I won't be truly happy with myself until I'm good at that too.
BPF, I may have 'Low and Slow' for a handle around here, and that's where my heart truly is, but it seems every few years I go a little bit higher and a little bit faster.
LnS.
hairdo
Re: DME Arc
Post by hairdo »
I actually did this "yay" method recently, worked really well! I hadn't heard it called the "yay" method until now. If I recall correctly, we slowed to somewhere around 180kt for traffic, and it worked just fine there, so I don't see why you wouldn't be able to do this method doing 200-250... so long as you stay on top of things.
Gravity lands us, we just make it look good.
AOW
Re: DME Arc
Post by AOW »
Gannet167 wrote:If you want to be really nerdy about it, you can calculate your lead DME to turn onto the arc. For a rate 1 turn onto the arc, I believe it's 1/2 your TAS, which you can get by multiplying your altitude in 1000's by 4 above 10,000', or by 3 if under 200 kts.
Ok, fairly good explanation, except in all the excitement you forgot to take 1/2 your TAS, so instead of 2.7 miles before, you should have used 1.4!
It is considerably easier (and in fact more accurate) to use your groundspeed rather than your TAS. Even if you for some reason don't have a GPS (shame on you!), you can get your g/s off of the DME display, so use your calculation based on 1/2 of this number (now to be quite pedantic, it is actually 1/200th (or 0.5%) of your G/S, you're not going to start your turn 135 miles from the arc!).
To mathematically derive this formula, lets figure out what we're solving for. You are planing on doing a 90º rate 1 turn to get on the arc. So the distance back to start is the radius of your turn. If you can remember back to high school , the formula we need is C = 2*Pi*r, where C is the circumference of the circle and r is the radius. We know C because you are doing a rate 1 turn, so you will cover 360º in 2 minutes, so C is the distance you will cover in 2 minutes. This is calculated as GS/30, so we can substitute that for C. GS/30 = 2*Pi*r, and with some rearanging, r = GS/(30*2*Pi) which calculates to r = GS/188.5. Is is fairly close to the rule of thumb number (GS/200), but is slightly larger, so always round up using the rule of thumb and you will be pretty close.
So for your example, if we assume a 270 kt groundspeed, using the rule of thumb, start the turn to intercept the arc 1.4 miles.
At this speed, the radius of your rate 1 turn will be 1.43239 NM, so you're not too far off!
