De-Ice bottles
tallyho
De-Ice bottles
Post by tallyho »
I am trying to find out where to buy handheld pressurized de-ice bottles (fire extinguisher size) with nozzles and the electric thermal jackets/heaters.
I know they exist, but despite much research I can't find anywhere that sells such a thing, can anyone help.
Tallyho
185_guy
Re: De-Ice bottles
Post by 185_guy »
Safety supply stores should sell a "piss pack' type of refillable backpack fire extinguisher, Canadian tire for a battery blanket to wrap around it to keep it warm.
RyanF
Re: De-Ice bottles
Post by RyanF »
Conquest Driver
Re: De-Ice bottles
Post by Conquest Driver »
I've used both types.
The system at Aircraft Spruce is the way to go. It may be a bit more expensive and you may have to carry spare fluid; but it works like the proverbial "hot damn".
BE20 Driver
Re: De-Ice bottles
Post by BE20 Driver »
One of the companies I worked for used a backpack garden sprayer with a battery blanket to warm the fluid. Best thing ever. Because it's a backpack, you can sling it over your shoulder and under your arm is the handle to continually pressurize the bottle. Much better than lugging around a fire extinguisher. Probably cheaper too.
The Hammer
Re: De-Ice bottles
Post by The Hammer »
Princess auto for sprayer, blanket may need to be made, heater is battery blanket.
tallyho
Re: De-Ice bottles
Post by tallyho »
Thanks guys, the aircraft spruce look good what with the nozzles etc, but a packpack type might be nice for climbing ladders for high wings and tail.
Also wondering if any of these need to be approved under a Grd Icing Program in order to be legally used.
Bede
Re: De-Ice bottles
Post by Bede »
tallyho wrote:Thanks guys, the aircraft spruce look good what with the nozzles etc, but a packpack type might be nice for climbing ladders for high wings and tail.
There is no such requirement. The requirement is to commence the takeoff roll without any contaminants adhering to any critical surfaces. How you meet that requirement is up to you.
200hr Wonder
Re: De-Ice bottles
Post by 200hr Wonder »
I will have to second what has been said, get the backpack type and a battery blanket. The shoulder straps will make it worthwhile. I have used both and having hands free to climb a ladder or use a squeegee is worth while.
200hr Wonder
HS-748 2A
Re: De-Ice bottles
Post by HS-748 2A »
A garden variety flower-watering pot full of Smirnoff, suspended from a crane will suffice.
This series of pics is top shelf on its own but the 'de-frosting' equipment here is a must-see..
http://englishrussia.com/2011/11/04/the-lucky-tu-154/
'48
ScudRunner
Re: De-Ice bottles
Post by ScudRunner »
The company I fly for has Fire Extinguisher style Bottles with a electric heater probe inserted into the bottom and a thermal blanket around it. It has a fitting on the top to attach an air compressor hose or a bicycle pump to pressurize it. The nozzle is your basic air hose quick release fitting that you can spray though or it attaches to a line off a collapsible metal pole with a nozzle at the tip.
It works great I use to be able to hose down and I mean hose down a 1900, wings and tail no problem. The Heater would keep it dam hot and the fire extinguisher style trigger is great with gloves on. Spraying the tail its a two person operation one waving the sprayer and the other holding the bottle and trigger sure beat climbing a slippery ladder with the garden sprayer or backpack type that would leak all over you.
One draw back is you better have access to a Air compressor or a decent bicycle pump trust me at -15 the plastic Cambodian tire super cycle do not cut it. Our company finally got the message after the 10 new ones they bought all busted in about a week.
Ill try to find out who makes them or if our Maintenance guys came up with it.
Better yet get one of these Soviet Style de Ice machines
http://www.lazydesis.com/chai-time/1430 ... rofit.html
BE20 Driver
Re: De-Ice bottles
Someone should tell those Russians that if they turn the engine around it'll be easier to race the Red Bull guy:
http://news.softpedia.com/newsImage/How ... ork-2.jpg/
privateer
Re: De-Ice bottles
Post by privateer »
Hey .. Your company seems to have the right stuff. Which company is it? :smt110
ScudRunner
Re: De-Ice bottles
:butthead:
