Jazz Pilot Bid Out
47north
Jazz Pilot Bid Out
Post by 47north »
Showing 48 new hires
Q400 replacing a lot of CRJ positions in YYC
dream_big
Re: Jazz Pilot Bid Out
Post by dream_big »
Where do you get 48 from? I see only 29???
47north
Post by 47north »
You are correct it is 29
Read it too fast. Might be some YYC CRJ pilots that aren't too happy.
cj555
Post by cj555 »
47north wrote: Q400 replacing a lot of CRJ positions in YYC
Does that mean that some of the CRJ Capts and FO's with the lowest seniority will be downgraded to the Q400? And with that comes a pay cut aswell?
rudder
Post by rudder »
29 plus attrition. Should be closer to 80-100 new hires at Jazz over the next 12 months. And as for the CRJ, there will be more reductions in that fleet type coming as well. Some replaced by Q400, some replaced by CRJ705/900, and some not replaced at all.
indieadventurer
Post by indieadventurer »
The Q400 holds 74 passengers, more than the 100 or 200 so some could see it as an upgrade imho. Also pay at Jazz is not based on a/c type so whether on the RJ/Q/traditional its all the same pay.
Go Guns
Post by Go Guns »
Is that statement entirely true? I mean, I understand it's the same pay scale at Chorus regardless of the type flown but, doesn't your status pay end up being averaged over all types flown by the group? By that I mean, when Chorus flew the 757, the pay rate for those crews was higher, but it was given to entire pilot group, so everyone saw a small raise. Now, is the pay rate for the Q400s the same as the pay rate for the CRJs they're replacing? Because if it's not, the entire pilot group will see a pay change.
Regardless, hiring is always good news. Good luck to those applying.
vanishing point
Post by vanishing point »
The '57 raised the rates a small amount but now that we're back to normal, it doesn't matter what one flies here, the pay rate is the same between types.
flyer 1492
Post by flyer 1492 »
Can someone post the equipment bid.
ChallengerDan
Post by ChallengerDan »
Go Guns wrote:Now, is the pay rate for the Q400s the same as the pay rate for the CRJs they're replacing? Because if it's not, the entire pilot group will see a pay change.
I am pretty sure that anything 90 seats and under is paid the same group rate, the number used to do the pay scale. So answer should be no change in the pay scale.
AutoPilot Off
Post by AutoPilot Off »
1 dollar per hour pay uplift across the board with the 757`s. SOOO that eqautes to an extra 80 bucks to all Jazz pilots every 2 weeks? every month?. would the depth of expertise on this webboard like to give an actual number..
rudder
Post by rudder »
AutoPilot Off wrote:1 dollar per hour pay uplift across the board with the 757`s. SOOO that eqautes to an extra 80 bucks to all Jazz pilots every 2 weeks? every month?. would the depth of expertise on this webboard like to give an actual number..
It was approximately $1.5 - 2M in incremental annual payroll expense shared amongst the entire pilot group.
rigpiggy
Post by rigpiggy »
how do they figure the pay rates, rasm casm.
D8-100 37*250=9250
D8-300 50*270=13500
CRJ200 50*430=21500
CRJ705 75*440=33000
D8-400 72*350=25200
considering that the Q400's are replacing the CRJ's you obviously need a pay raise
Taxi
Post by Taxi »
What's the equipment bid looks like ? Please.
honest joe
Post by honest joe »
Does anyone know when the next course is?
Could someone publish the latest bid?
Thanks in advance,
HJ
FL320
Post by FL320 »
honest joe
Thanks.
Anyone know how many open YVR slots?
DHC-1 Jockey
Post by DHC-1 Jockey »
- 34 new hires, with the first groundschool October 15th
- Vacancies after the results of the bid were announced:
- 1 YUL CRJ
- 6 YUL DH8
- 8 YYZ CRJ
- 11 YYZ DH8
- 5 YYZ Q400
- 3 YYC Q400
Green Onions
Post by Green Onions »
Where are you seeing the results of the bid? I cant find it on Jazznet anywhere. Funny to see it on avcanada before internal.
DHC-1 Jockey
It's right in the message centre under "informational."
Green Onions
strange... not in mine.
Stinky
Post by Stinky »
I found it in the same spot as bid packages.
Mig29
Post by Mig29 »
Good mix for the new hires!!
Lots of training movements this fall/winter!!
Good luck everyone!
TheStig
Post by TheStig »
rudder wrote:29 plus attrition. Should be closer to 80-100 new hires at Jazz over the next 12 months. And as for the CRJ, there will be more reductions in that fleet type coming as well. Some replaced by Q400, some replaced by CRJ705/900, and some not replaced at all.
Has any information with respect to further CRJ705/900 orders been made available?
mbav8r
Post by mbav8r »
Yah, 42 deliveries of 705/900 replacing remaining 100/200 aswell as some Dash8100/300s. First deliveries to take place with pluna 900s once import in place, then from factory, one a month starting Jan 2013. Also placed an order for 58 Cseries, starting feb 2014.
It's all there on flyjazz.ca under media
