Not a separate company, just another brand??????
Norwegianwood
Post by Norwegianwood »
"But Air Canada may be hard pressed to get the LCC off the ground in the early part of 2013 if it intends to the launch the carrier as an independent subsidiary.
The carrier has yet to apply for either an air operator certificate with Transport Canada for the LCC or to start the licensing process with the Canadian Transportation Agency.
Industry sources say that process typically takes up to 12 months to complete."
Source:- FP today! http://business.financialpost.com/2012/ ... t-airline/
chopsticks
Re: Not a separate company, just another brand??????
Post by chopsticks »
Well, in the article it states that the LCC will have a separate management team. I think that's great, because if there's anything Air Canada needs to do in order to cut costs is to add more layers of management!
yycflyguy
Post by yycflyguy »
chopsticks wrote:Well, in the article it states that the LCC will have a separate management team. I think that's great, because if there's anything Air Canada needs to do in order to cut costs is to add more layers of management!
HA!
TheStig
Post by TheStig »
Not so much additional layers of managers as duplicates...
BE20 Driver
Post by BE20 Driver »
If it's not a separate company but another brand, good luck trying to convince the unions they should be paid differently.
Weeks away from announcing something mean nothing. They could be 51.5 weeks away from actually doing something.
Norwegianwood
CLONES!
Based on same pay and same SIZE bonuses, you fly for smaller wages we take BIGGER bonuses........ :toimonster:
sarg
Post by sarg »
Norwegianwood wrote:"But Air Canada may be hard pressed to get the LCC off the ground in the early part of 2013 if it intends to the launch the carrier as an independent subsidiary.
Just wondering what happened to the OC for Canadian after the merger, might just be the simple matter of dusting off the one that's sitting on the shelf.
Return to “Air Canada”
