Quick question regarding the requirement to have done a Group 1 flight test within the preceding 12 months of the ATPL application date. Will a PPC for a Navajo certified for single pilot IFR satisfy this requirement? In my mind it should, as the flight test had all exercises required for a group 1 and then some. Just haven't been able to get a straight answer.
ATPL Group 1 question
				tired of the ground
Re: ATPL Group 1 question
Did the examiner renew your IFR? If yes, you're good to go. If not, did you do all the exercises that are required on an IFR? If you did, you're good to go.
(a) Within the 12 months preceding the date of application for the licence, an applicant shall demonstrate in a multi-engined aeroplane with no central thrust configuration and fitted with instruments and equipment suitable for IFR flight in controlled airspace, familiarity with and the ability:
(amended 1999/03/01; previous version)
(i) to perform both normal and emergency flight procedures and manoeuvres appropriate to the aeroplane in which the flight test is conducted; and
(ii) to execute all manoeuvres and procedures set forth in Division XIV for issue of a Group 1 instrument rating.
