No harm, no foul, just looking for some clarification.
Gramps
If that's how you feel, I hope you don't fly in the oil sands area.complexintentions wrote:Since when is not cancelling IFR "less than stellar airmanship"?! FFS.
(Snip)
Sorry you feel someone was "holding you up", but questioning someone's use of an IFR clearance is the real example of less-than-stellar airmanship.
Donald wrote:If that's how you feel, I hope you don't fly in the oil sands area.complexintentions wrote:Since when is not cancelling IFR "less than stellar airmanship"?! FFS.
(Snip)
The above however is the example of what we deal with in our airspace structure and is well said.tbaylx wrote:Normally I agree with you Complex, (think we have a similar ME background), but here i gotta say I disagree.
Unless there is some operational reason, asking for the visual approach in good weather to allow another aircraft to avoid a costly delay is good airmanship. We aren't talking about IFR radar environments where it makes little difference, there are many parts of the country here where if pilots didn't extend the visual approach courtesy to others operations would look like DXB in a thunderstorm or fall fog.
The oilsands and the arctic come to mind where if you don't cancel you'll keep another aircraft at 12000 until you land 10 min later. If its IFR or terrain or night and you need to keep the IFR then that's a different story, but if its day VFR i would accept the visual approach every time to allow another aircraft approach clearance.
The oil sands would come to a grinding halt if the operators in there didn't do that on a regular basis. Nothing at all unprofessional about it.
Ahh yes the exotic destinations of Fort McMurray, Fort St John and let's not forget about Saskatoon.loopa wrote:He doesn't... he flies 400 people to destinations you and I can dream of - making more than our salaries tripled.
His response is the example of a heavy transport category pic's decision making.
Lurch- I'm reasonably sure 'Complexintentions' doesn't fly for Jazz.Lurch wrote:Ahh yes the exotic destinations of Fort McMurray, Fort St John and let's not forget about Saskatoon.loopa wrote:He doesn't... he flies 400 people to destinations you and I can dream of - making more than our salaries tripled.
I'm sorry but if you dream of flying to Jazz destinations you need to get better dreams.
Some of us actually make more then Jazz pilots and also question why they don't cancel their IFRs some days. I ran into this twice in the last 4 days.
When did Jazz start flying "heavy transport category" aircraft?![]()
Lurch
So a circling approach is out the window as well, is it?complexintentions wrote:Since when is not cancelling IFR "less than stellar airmanship"?! FFS.
Your issue is with the ATC system that for whatever reason, is incapable of sequencing aircraft close enough that they can allow you to descend lower than you desired. That's not a hack on ATC, there could be terrain or technical reasons for it, but it certainly isn't another operator's obligation to switch from IFR to VFR simply to speed things up for someone else. No one is "hanging on" to their IFR, it's completely normal - and mandated - for most airlines to only allow IFR ops. Most have strict limitations on even visual approaches (which are still IFR procedures). It isn't an issue of weather conditions whatsoever.
What would you suggest Jazz do if for some reason they go around for a reason other than weather? (Unstable approach, windshear, vehicle on the runway, whatever.) They're basically now going to have to do a VFR circuit. In an RJ, maybe with a crew who's never been to YXS. Have they briefed it? Probably not. They fly IFR procedures all day long, but when was the last time they flew a circuit? So is that safer than following a programmed procedure with positive lateral guidance and assured terrain clearance? I think not. Sure, they can "do" it, but aside from violating company SOP's, it's just poor risk management. All so that another a/c can save what, two minutes?
But Prince George does have radar (SSR). They decommissioned the primary radar recently because it was unnecessary in Nav Canada's opinion, but that shouldn't cause them to suddenly switch to procedural control as far as I know.sstaurus wrote:Isn't that radar vs non-radar?
It sure is for many airlines. As a matter of fact since its silly to circle in a medium or larger jet at circling minimums anyway, we don't even train teh circling anymore, nor do it on a ride, so we legally can't do a circling approach. Circling a B737 or larger is a different ballgame than hauling a King Air around.Redneck_pilot86 wrote:So a circling approach is out the window as well, is it?complexintentions wrote:Since when is not cancelling IFR "less than stellar airmanship"?! FFS.
