IATRA STUDY MATERIALS
Apart from my limitations and performance
Any idea how many questions are on the IATRA?
any study materials and information will be helpful
Re: IATRA STUDY MATERIALS
http://www.tc.gc.ca/eng/civilaviation/p ... l-2343.htmtuskegee0147 wrote:Apart from my limitations and performance
Aerocourse....
Sharper edge....
Search the forums. Lots of questions on here
I'm currently using the harvs air online prep course... Very helpful ... Only downfall it costs about $220. (Well worth it)
The Michael . 2014 prep book for iatra and atpl is awesome.
Pricey , but with a couple of days of studying it you ll pass the iatra exam in a breeze.
And you can keep it and use it for the atpl
Andy
Andy
I've got the 2012 sharper edge ATPL book. FULL of info. I'm scrambling to write the IATRA this week.
Anyone who has recently written the IATRA, could you be so kind as to give us a heads up on what to study? There are SO many potential questions and TC gobbledegook, that I'd like to know where to focus. The TC study guide is particularly useless!!!
I'd write the SARON and SAMRA now (I have the reqs.), but I'm short of time and $.
I had about 8-9 ifr questions, 5 or 6 were gps, lots of general stuff, search on here for it and you'll get th bulk of the questions, almost everything i read on here showed up on the test
I wrote it less than two weeks ago.
Make sure you know how to read and understand perfermance charts.
W&B calculations
Flight duty times and crew rest
Have a look at your ifr study and notes
Aproach bans
The definitions and what you can and can't do according to 702-703-704-705 ops
Go in relaxed, bring a flight computer for the love of god, that's the answer to at least 4 questions!
W&B calculations
Aproach bans
I always remember to bring in the ol' E6B! it is after all, the dark ages still, at TC
Also found and read through some of the older exam questions from 2009-10 and 11 that were on here.
Re: IATRA STUDY MATERIALS AND IATRA PRACTICE QUESTIONS
Did the exam got an 88%
Here are some of the stuffs that will be handy to study
1.Calculate landing weight using a take off performance graph
2.Calculate maximum payload MZFW-BOW
3.Explain how to detect thunderstorms using airborne weather radar
i think its turning the range mode and then tilt the antenna beam to scan middle/lower area of CB first
4.Recall ATC procedures when cleared to an uncontrolled airport for an approach?
five min prior to begin approach
circling approach
missed approach
O.B of procedure turn or if no PT turning final
crossing FAF or if no FAF 3mn before landing
turning final
5.Recall flight plan alternate requirements? all IFR flights
6.recall flight plan weather requirements for alternate aerodromes RAC3.14
7.recall how to obtain SIGMET informatiomMET3.18
8.Recall privileges of CPL holders on type on a two pilot aeroplane?co-pilot on type
9.Recall recommended minimum altitudes for flight within designated mountainous regions?Also the minimum altitude in very cold weather? ans were like 1000 ft above MEA,1000ft above highest obstacle, 2000ft above MEA, 2000ft above highest obstacleRAC2.12, RAC8.6
2000-zone1 and 5
1500-zone2,3,4
10.flight duty time regulations for a commercial air service? 14 CAR700.16
11.Recall the requirements and procedures for GNSS approaches? COM3.15.5.2.2, 3.15.5.2.1, 3.15.2
12.Recall the requirements for applying cold temperature correction? i think its published min IFR alt
13.Recall restrictions regarding alcohol and drug use?CAR602.03=8hrs, AIR3.9=min24hrs
14.Recall TSB accident reporting proceduresGEN3.3 asap
15.Calculate cruise performance
16.calculate TAS
17.demonstrate requirement for 2 way communication (if flying IFR in VFR weather)?
18.Identify maneuvers that will minimize CAT encounters?
question was like if in northern hemisphere and OAT is constant what will u do to avoid CAT? i chose alter heading to south, options were maintain heading, climb or descend as convenient(i think this is the ans) or alter heading to N
19.identify thrust measurement indicating systems and operating principles
20.Interpret vasis indications?upwind and middle bar for a/c with.......? EWH of 25 , EWH of 25 or less, EWh of 25 or more
21.Recall conditions favorable to surface contamination? question was like areas to first deice? answers were like tailplane, upper fuselage, area inspected by person in cockpit, representative surfaces( question threw me off and was looking for an answer close to critical surfaces so picked tailplane and got it wrong)
22.State the vertical dimensions of the ADIZ? from surface, 2200-FL1800,3000-FL18 etc
23.Compute critical point? Use ur flight computer, its ur friend
distance to cp=D*Hr/Or+Hr where D=total trip distance, Hr= reduced g/s home and Or=reduce or 3 eng g/s out
This is all i can remember for now but feel free to mail me if you have any further questions
Other helpful questions are posted on this site and on the ATPL/INRATaerocourse workbook .
circling approach
missed approach
turning final
2000-zone1 and 5
1500-zone2,3,4
16.calculate TAS
hello
can u please share any study materials and questions regarding inrat and iatra as i am planning to write next month
did you try aerocourse workbook or dauntless website?FlywithPalak wrote: ↑Mon Mar 11, 2024 7:48 pm hello
