IFR clearances and "Clearance Cancelled if not airborn by X"
Posted: Wed Mar 19, 2014 1:32 am
Curious about how things work behind the scenes when I get my clearance, and the differences between me getting it from an airport thats controlled, one with a FSS and from aerodrome with no agency.
Last night we departed a larger airport in the wee hours of the morning (Read MF vs Tower Controller). After recieving our clearance Medics informed us they forgot something it was going to add 10-15 min until we could depart. Other pilot thought we had to leave it behind or cancel our clearance, I thought we could just advise the Radio, (as a courtesy so he was in the loop) and wait while they sorted it out in the back. Ended up being a non-issue and we left right away, but it got me wondering.
At an airport with a control tower, I don't expect any sort of "Clearance cancelled if not airborn by XXXX" because I assume the tower controller passes it on to center when we take off and the IFR controllers space according to when we acctually leave.
When the tower is closed but its an MF I assume the FSS performs the same task, and as such I would not expect any sort "clearance cancelled if" clause.
Should I depart an aerodrome that is in uncontrolled airspace, with the intention of entering controlled airspace, when I call center up on the phone to get my clearance before departing I WOULD expect that clearance to contain some sort of "clearance cancelled if" clause, because in this case no one is there to give the terminal controller a heads up that I'm airborne.
1.) I know the AIM says I have to advise ATC if I wont take off within 60 min of my filed time to avoid SAR launching, but what if any requirements exist outside of this?
2.) If I'm back at that MF airport and after I get my clearance something comes up delaying departure what happens to my clearance? Of course I'm gonna let the FSS know if we're gonna be a while, but how much is a while? 15 min? 30? 60? do you guys protect the airspace along my route up to the time of my propsed eta even if theres something to tell you "no he hasn't left yet"
3.) The AIM states an IFR clearance recieved at an uncontrolled aerodrome "may" contain a restriction or cancelation, but shouldn't there have to be one every time?
