Closing Of Halifax Terminal
Posted: Fri Jun 13, 2014 11:23 am
It's time for me to stop watching and start talking. For the users of Halifax Terminal, this is the reason you may get holds/delays in the near future.
It was finally announced by management that Halifax Terminal would change from a stand alone terminal unit and be merged into an existing low level enroute sector in Moncton Centre. All controllers from low level (many who have only worked en route for their entire career) will be required to "train" in the terminal sector and vice versa. Contrary to the advice from controllers that this would not be simple task and not everyone is cut out to be thrust in to a situation they are not used to, management is adamant that atc is atc and if you cannot do both terminal and en route, you should not be a controller (ie: "You drive a car on a highway therefore there is no reason why you cannot drive this F1 car safely")
Management has stated time and again, that there should be no decrease of level of service to the users and so they have not informed the airlines that use Halifax on a daily basis. Management has also said that if traffic level is such, that the normal in trail spacing that is currently provided (3/4/5/6 miles, 10 miles for CatII, 12 miles for LVOP) is unable to be attained by the enroute controller now working the Halifax airspace, they would accept that the controller puts aircraft into holds until they are able to clear the aircraft for approach. A method that is used, and is acceptable, at smaller airports in an enroute sector. In other words, enroute controllers being trained to work in the Halifax airspace would not need to demonstrate minimum spacing between arrivals as would any other trainee in the past (ie. "you can't vector for 3 miles, why don't you try for 6 miles. At least you won't have an incident.")
No one has asked, but I'm sure the same would apply to a terminal controller (who is used to working a radar environment) training in the enroute specialty who is not comfortable using non radar techniques at CYGR and leaves the second departure on the ground for an extended time because they are not used to procedural separation standards ("Well, at least you didn't have an incident").
Training, so far, has not gone as smoothly as management has liked. Trainees have been, so far, held to a standard that is dictated in the UQTP (unit qualification training plan) and those that have had issues in qualifying, the instructor has been blamed for holding the trainee to standards higher than what management has seen as required. As a result of this, management has decided, from this point forward, to ignore the UQTP and the trainees need only to demonstrate that they have the ability to keep aircraft separated and they do not need to show the ability to run an operation with minimum arrival spacing. If these trainees need to hold aircraft because final has been extended due to increased spacing, that is acceptable. If they are unable to use two runways for arrivals, then they are to use one runway only, to keep it simple. This has not been acceptable in the past.
Quite simply, we controllers are a proud bunch. We like doing our job well. We recognize that not all air traffic control is the same. There are those who succeed in towers, those who do well controlling high level, those who thrive in a non radar environment, and those who enjoy working in a terminal environment. Many have tried a different specialty and found they are unable to do the job while at the same time being an excellent controller in a different specialty or unit. Our concerns about a management "efficiency" initiative have been ignored and we are not upset because this is a managerial decision, but we can see the level of service to our users being diminished and our quality of work decreasing. This hurts. We feel we have been, proudly, providing a good product so far and this will not be a better operation.
We are not fooling ourselves in comparing our specialty to terminals like Toronto, Vancouver, Montreal, Calgary etc. but we do have an eclectic mix of traffic. Mixing Sea Kings flying IFR approaches while sequencing 737's behind him is no easy feat. Helicopters coming back IFR from the oil rigs with minimum fuel are vectored for approaches with little delay and at the same time the airlines are put in behind them without being greatly affected. Running arrivals on crossing runways with minimum separation is definitely an acquired skill that requires constant polishing. And lets not forget the ever present fog. Working this mix is not for everyone. It is also a skill that requires working it every time a controller "plugs in" in order to keep one's skills tuned.
My reason for this post is that I am afraid that the company has most likely not informed the users that there will be a change of service. Or if they have consulted them, management has assured them that there will be no change. This is contrary to the statement that management has told the controllers where holds and increased spacing is acceptable.
Rant over!
Rant over!
