Canadian North Incident
Elliot Moose
Post by Elliot Moose »
Okay, maybe I missed a previous thread but.....
This was published in the Aviation Herald just today. Mods please lock this up if it was already posted!
Your Ad here
Incident: Canadian North B733 at Fort MacKay on Dec 17th 2013, uncommanded left roll despite full right ailerons
By Simon Hradecky, created Monday, Jun 23rd 2014 21:19Z, last updated Monday, Jun 23rd 2014 21:19Z
A Canadian North Boeing 737-300, registration C-FGCN performing flight 5T-1517 from Fort MacKay Albian,AB to Edmonton,AB (Canada) with 139 people on board, was climbing through about 800 feet AGL when the aircraft began to uncommandedly roll left. The crew countered by applying full right ailerons, the roll to the left however continued. Airspeed began to decay, the crew applied nose down inputs, however, the aircraft reached a nose up attitude of 28 degrees despite the control column commanding nose down. The airspeed finally recovered and increased permitting the crew to retract the flaps after which the left roll ceased. The crew checked engine parameters and configuration with no anomalies detected and decided to continue the flight to Edmonton for a safe landing with no further anomaly observed.
The Canadian TSB reported the occurrence for the first time on Jun 23rd 2014 stating, that the weather conditions at Fort MacKay's Albian's Airport were -22 degrees C with moderate snow. Immediately prior to departure the aircraft was de-iced with type I followed by type IV fluid. Departure roll and rotation were normal. According to flight data recorder the aircraft reached a maximum left bank angle despite maximum right ailerons and a pitch attitude of 28 degrees despite the control column in a 10 degrees nose down position. After the speed recovered the crew retracted the flaps, the left roll ceased, the crew checked engine thrust settings and leading edge devices, all parameters were normal. The crew decided to continue the flight to Edmonton without declaring emergency. The crew used a reduced flap setting for landing. The airline and Boeing are further investigating the event.
http://flightaware.com/live/flight/MPE1 ... /CAL4/CYEG
You can't make honey out of dog sh!t
AllClutch
Re: Canadian North Incident
Post by AllClutch »
I'd be doing a 180 back to Fort Mackay if I were them to go find me a fresh pair of shorts.
fish4life
Post by fish4life »
Definitely a scary situation for the crew.
rigpiggy
Post by rigpiggy »
AllClutch wrote:I'd be doing a 180 back to Fort Mackay if I were them to go find me a fresh pair of shorts.
As was commented on avherald, why the problem stopped with flaps up, probably a flawless or reduced flap landing. 7500' or 11000', full cfr or call lout, big hospital with trauma center, or much smaller hospitals...... Good job boys!!!
GRK
Post by GRK »
Wow…pretty close shave! Does the -300 have EICAS? (Can't recall) Most 737 operators use 5 flaps for departure to optimize climb performance, I would guess that there should be some sort of asymmetry protection (hence the EICAS question) and certainly some sort of caution would be generated as soon as the asymmetry occurred, or was sensed... like right after selection of position. I wonder, if this was the case, where the roll was generated? Was it flaps? Was the 800 foot altitude roll occurrence related to speed increase? Were flaps selected after the last application of fluid during the taxi out? Did anyone do critical surface inspection after de-icing? Lots of questions…nice job by the crew to keep it airborne!
Fly safe!
GRK
No EICAS on the -300. All of the Classics have dual needle flap indicators though.
