C-208B start temp
andy_mtl
C-208B start temp
Post by andy_mtl »
I fly a C208B for a skydive centre and we noticed this year a raise on start temperatures which makes us wonder if we should update to maybe the 300A starter generator.
The current Gen we have is a 200SGL119Q-2
On a 28 degrees Celsius day at 200asl we are getting
Battery start:760-780 degrees on start and the battery is 2 weeks old
GPU start:725 740 and it is a 28 volts startpack.
We used to get last year averaging temps of 660-680 on a hot day.
Any inputs? Would a new generator help? I have a friend that suggested the 300 A as it is a stronger motor but would it help for a colder start?
Any info is greatly appreciated.
Andy
Boreas
Re: C-208B start temp
Post by Boreas »
Is 760-780 really an issue?
You can climb-out at the lower end of that
range, so is it all that bad for an engine
start?
How many hours did it fly in the last year?
100deg increase does seem like a lot.
I would ask if its running hot in cruise as
well but I guess you don't do much of that.
andy_mtl
Post by andy_mtl »
It flyes am average of 450-500 h per season.
In climb we limit at 740 not 765.
The temp isn't hot per say, but as you stayed is the increase from last year that worries us a bit.
The engine is about 1600 since new
Andy
longjon
Post by longjon »
why would a 300 A S/G be better than a 200 A.? The determination of start temp is directly related to the speed of your Ng when introducing Wf. If your battery is good and you get your 12, 14 or 16% or whatever the book calls for then it's not the starter or battery but cold section problem or a hot section problem, read the troubleshooting section of the P&WC Maint Manual as there is a very good chart on exactly this
andy_mtl
Post by andy_mtl »
Again, that was suggested to me by a friend with 1200 h on a caravan .
What we notice is the spool up time between 25 to 40 on the ng is very long.
He told me with the stronger motor on the 300A it should be solved.
I just the pilot not the mechanic
Andy
longjon
Post by longjon »
Or replace the original S/G if its the problem. You are describing 2 problems. the long spool up time before introducing fuel and 2nd the hotter start after reaching desired start Ng. Is the S/G dragging and slowing the spool up? What if you introduce fuel and the S/G doesn't allow the Ng to spool up and you cook it?
Also it's running hotter than last year so another problem not related to starting. If your Wf and Ng are increased to maintain the same Tq then its a cold section problem, if your Ng has not increased and your Wf is the same but the T5 is up its a hot section problem.
I'd be calling the Engineer doing the maintenance and get it solved.
andy_mtl
Post by andy_mtl »
Ok thank you for that.
We are Sked a maintenance this week and we ll see what he says too.
Appreciate it
GA MX Trainer Dude
Post by GA MX Trainer Dude »
Andy mtl
I don't have a lot of time on the 208 but I do have 40 years on PT6 engines. All of the installations that I have seen include a "Field Disconnect Relay" - or something similar but called a different name - that is installed in the "Generator" Field circuit.
The purpose of the disconnect relay is to prevent the starter generator "Generating" during an engine start.
When you activate the start sequence the field disconnect relay is usually powered "Open" - thus preventing electrical flow through the generator field and preventing the generation of electricity while starting.
If the field disconnect relay doesn't open then some of the power from the starter motor is being used to generate electricity in the generator side. This results in a normal spool-up at the start - but from about 25% and above causes a longer start time and higher temperatures during the start due to the reduced power available for accelerating the engine.
Have your maintenance guys check the system to see if this is your issue.
Regards,
Mx
You can train a monkey to ride a bicycle but you can't train it to fix it!!!
GyvAir
Post by GyvAir »
I agree with longjon.. if the 200 amp s/g was adequate last year, it should be adequate this year too, so, you have a different problem. (Would it make any difference to spool up times having a 300 amp v.s. 200 amp rated starter-generator anyway? The rating is referring to the output. Is the starter amperage draw proportional?)
Could it be something as simple as a deteriorated cable or connection?
TeePeeCreeper
Post by TeePeeCreeper »
Andy,
I agree with you that the ITT your seeing on start up seems a bit high...
I am accustomed to seeing 685-700 on a cold start at sea level on +38 degree mornings when I worked in the sandbox.
Are you getting the 80-110 90-120 PPH (depending on what kind of nozzles) on your fuel flow gauge?
If I were in your shoes I wouldn't loose any sleep on it just yet...
All the best,
TPC
Chuck Finley
Post by Chuck Finley »
Seen the same issue on a different AC that was powered by a PT-6 after a battery swap. They cheaped out on the battery and after about a week, the starts were getting hotter and hotter ( don't remember numbers ). They changed the battery again with a "better one" and the issue was fixed.
andy_mtl
Post by andy_mtl »
Teepee
On first start of the day I get 680 690
I normally fuel for 3 loads then shut down and like today at +30 I did 5 starts and all between 720-740 with the gpu I wouldn't dare doing it with the battery.
I paid close attention to the fuel flow:
As soon as I move the fuel lever it jumps to 100, then 140 and drops down to 110 as ng raises past 40, then settles at 130 pph.
With the gpu we introduce fuel at 18 ng a bit higher than as per POH but it was suggested by flight safety to my boss when he did his training , for starts that are done on a hot engine.
The new battery we got isn't a cheap one.
We are all a bit overly concerned with hot starts and the last place one wants to cheap on is the battery in my opinion.
Cheers guys
Boreas
Post by Boreas »
GA MX Trainer Dude wrote:If the field disconnect relay doesn't open then some of the power from the starter motor is being used to generate electricity in the generator side. This results in a normal spool-up at the start - but from about 25% and above causes a longer start time and higher temperatures during the start due to the reduced power available for accelerating the engine.
Interesting, MX.
Would you get a Gen Amps readout if this
was the case? If so, you could easily
confirm the situation.
GA MX Trainer Dude
Boreas
Not that I have ever seen.
My understanding of the effect is that the generator windings act as a "Dynamic Brake" that works against the starter effort. In the same way for example as the gear motor dynamic brake action of the King Air electric electric motor when it is shut off. The electromotive braking action stops the motor almost immediately.
With twin engine aircraft we would just change it - or if away from base swap it with the other side to check. On most aircraft it isn't a big job to change.
I have seen battery, starter generators , and generator control units changed trying to "Shotgun" troubleshoot the problem.
If the field disconnect relay fails in the open position - rather than the closed position (Usual) the generator will not come on line. This is also why the generator won't come on line in the King Air when you forget to switch off the starter!! I always have to have a checklist item to remember to unlatch the starter switches on the King Air as so many other aircraft have the spring loaded start switches rather than the latching type. Like I stated in my original post I don't have much time on the 208. Have a look in the wiring diagrams for the generator system and it will show if you have the relay - so "easy peasy" to check.
Hope this helps.
Mx
Edit to add:
Beech King Air 200 Mx Training Manual excerpt.
Generator Control for BB-88 and after, BT-1 and after, BL-1 and after,
and BN-1 and after
The generator control switches are located under the Master Switch gang
bar on the pilots lower left sub-panel to provide the crew with control over
the starter-generators.
Whenever the generator control switch is in the OFF position, battery
voltage is routed from the generator control circuit breaker through the
generator control switch and the normally closed contacts of the field
disconnect relay to the field grounding relay which shorts the shunt field of
the respective starter-generator to the airframe structure. Regulator power is
interrupted, and, consequently, generator operation is disabled whenever
the generator control switch is selected OFF or when the respective engine
is being started.
During engine start, the field disconnect relay is energized, thus interrupting
the coil circuit of the field grounding relay.
Mx
username here
Post by username here »
Nobody has mentioned the possibility of a bleed air leak causing high temps. Are your cruise trending temps higher than last year as well?
I would blank off the engine bleed air port first and see if that helps.
andy_mtl
Post by andy_mtl »
Unfortunately per every 100 hours I fly I do maybe 1 h cross crown try for maintenance so not really much cruise experience.
Tho I fly with shorts and I have the hair always set to fwd cabin not defrost so if I had a leak I would feel it I think.
Andy
username here
No you would not feel a leak. It wouldn't take much to cause a rise in ITT due to a bleed air leak. Could be the bleed air gasket at the engine case or possibly a leak in the bleed air flex line. Best bet is to blank off the bleed air and see if it makes a difference. Easy enouh for your AME to do.
Heliian
Post by Heliian »
You are a commercial operator. Snag it in the log and have an engineer look at it, could be a multitude of things. But you wouldn't want to be inconvenienced with silly things like actual maintenance. Maybe it'll make the next hundred? Maybe you'll torch the engine? Raise the bar for once instead of carrying on the tradition of clapped out p.o.s. meat bombers.
andy_mtl
Post by andy_mtl »
Easy now.
As previously stated this aircraft is going I this week , and the beginning of the thread was a simple Question on weather or not a 300a S/G would develop better starts.
Now we all started talking about other possibilities and it's actually quite good to know all the different causes that could generate a hotter start than normal. Most of us are just pilots so it's good to have an engineer point of view.
As per he plane I fly, it's the newest c208b doing paradrop in Canada.
Fully functioning autopilot, tcas, weather radar, have a ETM that I download weekly and send in to be analyzed .
This isn't naves surely a snag, the aircraft didn't go from 650 degree start to 900 overnight.
Andy
YYCAME
Post by YYCAME »
Always good to make sure your ITT is properly calibrated before chasing stuff like this so you know its not just an indication problem, though it sounds like your normal run temps havn't changed so that probably isn't significant in this case. While as a pilot you won't be boroscoping it is always a good idea to use a flashlight down the inlet to check for significant blade damage on the impeller from FOD. I think if you had a bleed leak you would probably see it reflected a bit in an increased fuel burn and ITT overall and not just on start though probably would be hard to track unless you were very familiar with the normal numbers for that particular engine. While those other suggestion are probably more likely causes I would ask the very basic question of whether the GPU is actually providing proper power, because maybe your actually doing battery starts due to some sort of blown current limiter or bad external power relay.
andy_mtl
Post by andy_mtl »
I tought if the gpu that could have lost power, so I used the gpu at the FBO here in Gatineau that is directly powered by the grid, and got maybe 5-10 degrees colder starts.
As part of my walk around I take my iPhone on video mode with the light on and put it in the intake and video the inside to see if anything is stuck on the screen. (Tho in Gatineau the runway is excellent in one of our bases it's gravel)
And so far I haven't seen anything on it.
Andy
revr
Post by revr »
Heliian wrote:You are a commercial operator. Snag it in the log and have an engineer look at it, could be a multitude of things. But you wouldn't want to be inconvenienced with silly things like actual maintenance. Maybe it'll make the next hundred? Maybe you'll torch the engine? Raise the bar for once instead of carrying on the tradition of clapped out p.o.s. meat bombers.
First off this is not a snag! call pratt and tell them your engine is starting at 800 degrees and they will say "so what"! as long as you are not exceeding the limits it is still serviceable. they tell operators this everyday.
in reality nobody wants there engine starting hotter than normal but the point I am getting across is that this should not be snagged because it is not a defect! still should be investigated though.
the 300 amp starter gen will give you much cooler starts due to the higher spool speeds, on battery it will spool your engine to 19-20% NG and on GPU you will see up to 22% NG. but this is not the fix to your problem as you must have a different issue, the 300amp SG will just mask the real issue, a good upgrade to do after you find the real issue though.
the bleed air leak mentioned above is a good suggestion.
you also mentioned that it seems slow to come up after fuel is introduced, this could be caused by a sticky flow divider, around 30%NG you should be able to hear the second start, this is when your secondary nozzles kick in, if its early or late it can cause a hotter start.
do you record your start temps? if it has been hot started and there is engine distress the first place you will see it is start temps.
the spike to 140PPH on fuel flow during the start is normal, if you start to see above 150 than you will get hotter starts.
next check min flow, it may be high or it may be low, the most important thing when it come to starts is to get the start completed as quick as possible, if min flow is low your start will be slow which lets the engine to build up more heat internally which will lead to a hotter start. if its high there is too much fuel which will lead to a hotter start.
not sure if you have the new style CT blades or not, but I would suggest a borescope inspection of the hot section next.
what is your generator load after the start? higher than normal?
also you should complete a performance run and check the numbers and see if anything is being exceeded.
REVR
andy_mtl
Post by andy_mtl »
Revr,
Following a maintenance check,
They kind of laughed when we said we were worried of a 740 degree start.
Bleed air had no leaks, and the gen was found serviceable.
This Thursday ( first day from the maintenance) I got 7 starts at 720 on gpu, and it was above 28 degrees out in the afternoon.
Tho we are looking into the 300 amp S/G.
The engine had a trend monitor , so every start and every second of flight is recorded, I download it once a week, and send the data up for reviewing from a company that deal with ETMs.
Andy
Heliian
Post by Heliian »
Could be:
Itt calibration
Fuel nozzles
Bleed valve
Battery
Starter brushes
Fod compressor
Worn clearances internal to engine
Dirty compressor
You would be surprised though, durimg an inspection once I found a compressor leading edge bent almost at a 45 and the engine still produced power.
Try a power assurance check and see if you have high itt or high ng.
If my a/c had all of a sudden a 60 to 80 degree increase in temps. That qualifies as a snag.
I apologize for the snippy remark earlier, its just that im seeing more and more neglected aircraft and more owners using the Internet to troubleshoot problems that one on scene engineer could easily handle.
revr
Post by revr »
if you upgrade to the 300 S/G and your maintenance team has not been around one than they need to watch the cooling fan on the starter gen, they are notorious for coming loose, they should be checked at least every brush check, also the extra cooling duct that gets installed on the nose gear spring fairing tends to rub on the nose gear and also puts extra strain on the spring fairing and they crack. the 300 amp SG is awesome for start temps and the 200 is better for everything else.
Return to “Maintenance”
