Whats your Shortest non stop flight?
Re: Whats your Shortest non stop flight?
Personally, a 5km flight from a nursery where I bought a Lavender plant then back to CNY3.
Although I met a guy once who was called in on his single Beaver to transport barrels of something across a trench. The trench was 10m wide and they had no way of moving the barrels across it. So, he landed on one side, loaded her up, took off and landed on the other side of the trench. Repeat for a few hours.
Daniel Gustin
Online Ground School
Not so short compared to many here but shortest for me and on the way back from Oshkosh. 06D (Rolla, ND) to S28 (Int'l Peace Garden) - 18 miles. Notable mostly because S28 is a fairly cool stop as you land on top of a hill and walk down to either US Customs or Canadian Customs depending which direction you're going.
Mark Twain
Mark Twain
Flying around all the BC lower mainland airports were some pretty short flights for me ypk-yly-yxx... but slow and simple airplanes make it like driving down the block...
YYZ-YTZ in a -8 was probably the shortest great circle for me flying commercially, 11nm, but track miles were more with all the handling.
YBW-YYC in a King Air was quick.
14 NM
SJC-SFO in a Boeing was really quick.
Great circle map says 26 NM but felt like less
Straight out SJC 30L, sid cancelled, cleared straight in SFO 28R.
14 NM
That’s the thing with faster planes and terminal airspace. Done YYJ to YVR and back and YVR to YXX but plenty of track miles were added by vectors.
CYAM to KANJ, 6 nm. Went there when YAM was out of Avgas and that was the closest airport.
YMO to moose factory 2.5ish miles.
Winner!Schooner69A wrote: ↑Sat Dec 08, 2018 9:38 pm From the end of the runway to where I landed: about 1100 meters
From the end of the runway to where the airplane landed: about 2500 meters
Many years ago when I kept my aircraft in the Wardair hangar at YYZ and had to taxi from Customs at the north end back to WD. Called ground for taxi and was subsequently cleared "take off 15, cleared to land 24.
I used to keep the 310 on the apron at Field at the north end, just across Kilo from the customs circle. I'd shut down in the circle to clear customs, and often have a challenge starting it again to taxi 100 feet to the parking spot. I begged Customs to allow me to taxi into their circle, wait for their acknowledgement, then taxi and shut down in my spot for inspection there, but they would never agree.taxi from Customs at the north end
Cessna 185 amphib from Fort Providence airport to the water at Whitlock Island. The job was to man up a Coast Guard ship which was wintered next to Whitlock island. The only way to get to it was to fly 5 miles over the ice flows to open water by the ship. Manual pump...85 strokes to get the wheel gear up and land in the water 4 minutes later. Off the water and 50 strokes to get the wheel gear down to land on the runway 4 minutes later. Repeat....12 trips.
Did that one. I was getting paid like 7 cents a mile. Earned less than a buck that day.
A couple of times while doing circuits in Abbotsford I've been told to extend downwind and have almost hit Lynden. Less than 6nm
YRT-YXN and YHD-YXL both 37 NM. 10 minutes in a king air, slightly longer in a light twin.
CYQG to KDET. It's about 8NM as the birds fly. We use Coleman to clear customs and pick up fuel if it's less expensive. Doing the EAPIS, booking a customs appointment and opening the flight plan takes way longer than the flight.
I flew some circuits at Abbotsford some years ago on my student pilot permit. I checked the ATIS before I departed, noted that the active was 25 and discussed the airspace implications with my instructor.prettyFLY4awhitegal wrote: ↑Sun Dec 09, 2018 8:00 pm A couple of times while doing circuits in Abbotsford I've been told to extend downwind and have almost hit Lynden. Less than 6nm
He told me that The Authorities would take exception to me filing a flight plan to Bellingham (or Victoria, via U.S. airspace), but a wide downwind at Abbotsford that happened to be a few meters in to Whatcom County wouldn't be an issue.
...laura
2.5 NM, from Port-au-Prince's old military airfield, Bowen Field, to Port-au-Prince International, twice, once in a Beech F33C, a second time in a Beech E-18S.
Last edited by Gilles Hudicourt on Mon Dec 10, 2018 11:33 am, edited 1 time in total.
Port McNeill to Alert Bay. 4.3 NM
Robshelle
Robshelle
Fort Frances Ontario to International Falls Minnesota. PA31-350 six miles in a straight line.
St Andrews to Winnipeg. 12nm.
Not the shortest flight possible, but I flew that corridor at least 315 times...
Under 5 minutes wheels off to wheels on in a 737.
I do this leg all the time. Takes about 3 minutes by Caravan. Every day I will do numerous flights between the islands in Belize that are less than 5 minutes long.
