Hawkair Engine Failure
gonefishin'
Flying back to YVR tonight and heard Hawk 392 state they had an engine failure with 13 on board, they diverted to YXS, anybody know any more?
Yeah they just lost one of the bleed air lines to their fuel metering unit so fuel + spark but no air. It was a quick fix, they just sent in another Dash8 to pick up the pax and bring in engineers and bring them on to YXJ/YDQ just a 2 hour delay. Just the way she goes sometimes!!!!
- tripleseven
- complexintentions
well no but air is.
The way I read the post the bleed air is used somehow by the fuel metering unit? If that was malfunctioning then I could see it preventing air getting to the fuel and ignition.
But I'm just speculating - any AME's out there shed some light?
Hey do you really fly the 777? cool.
- tripleseven
Sparkfarmer
- tripleseven
OK, firstly I have never done maintenance on the PW100 series engines but have a bit of time on the PT6s which in theory should be basically the same but I'm not sure so take this response with a grain of salt.
If you lose bleed air back to the FCU (on the PT6 this is P3 if I remember correctly), the FCU will roll back to a min fuel flow condition. For maintenance purposes we disconnect the bleed air to adjust min flow. This should not cause a flameout.
Additionally, once the engine is lit, the ignition is generally shut off unless SOP requires it on ie. heavy precip. Continuous fuel flow maintains continuous combustion. The turbine engine is a continous air flow engine unlike a piston engine so once the fire is lit, it'll stay lit with no further ignition source till the fuel is cut off.
On all turbine engines that I am aware of, there is no way to limit airflow mechanically to the engine except possibly engines that operate in the supersonic corner of the envelope where there is control required to ensure a shock wave does not enter the inlet area.
Only the maintenance dept for Hawkair have any idea as to why it quit.
ETTW
ETTW
Hornblower
Correct: It is P3 air that is used as a reference pressure for the MFC or HMU depending which PWC 100 series engine. This pressure is also fed to the prop overspeed governor. If there is a leak in the P3 sense line, which this engine is prone to have you will not make T.O. power and you will have power leaver splits.
- bob sacamano
I have nil for experience on PWC 100 series engines but lots on PT6's and P3 air is used in the FCU and in some cases, the PCU as a reference for fuel scheduling, engine acceleration and prop overspeed because P3 air pressure is dependent upon engine speed or Ng. If the engine is overspeeding, it is sensed as increasing P3 pressure and the governors can overboard or reduce the pressure and as result reduce fuel flow which will reduce RPM. Wish I had my notes close at hand for a better explaination but that is in essence what happens.
- Bubbaganoosh
Sounds like HA may have a little more to be concerned about than the blither blather about what may have caused the engine shut down..
http://www.terracestandard.com/portals- ... 6106&more=
I like that.. at the end of the article it mentions that you better watchout for the ones who may be lat go.... Look out guys.. here comes the knifeBubbaganoosh wrote:Sounds like HA may have a little more to be concerned about than the blither blather about what may have caused the engine shut down..
- tripleseven
