flight time
				indieadventurer
flight time
I was having a discussion with a colleague of mine regarding flight time. He never became airborne on a flight and said he couldn't log the time, even though he had the intent to get airborne. Shouldn't he be able to log it?
					Last edited by indieadventurer on Thu Jan 14, 2010 6:37 pm, edited 1 time in total.
						Re: flight time
You can log the time. Put it under Ex.4
Timing is everything.
				indieadventurer
Re: flight time
how'd you guess?Tango01 wrote:You can log the time. Put it under Ex.4
Re: flight time
I would log the time in the PTR as taxi time, but I would be hesitant to log it as flight time. I can't find it now, but there's a regulation specifying that the aircraft must leave the ground for it to qualify as a flight, and there's a maximum amount of time which can be spent taxiing for every hour of air time. It's to ensure that students, and other pilots, don't just build time by idling in the run-up bay.
Re: flight time
Flight time is defined as the period of time from when the aircraft moves under its own power for the purpose of takeoff until the aircraft comes to a stop at the end of the flight. It's loggable. And I wouldn't call it padding the book at all, presumably they decided to decline the flight for a reason, and that's experience whether they got stick time or not.
				turbo-prop
Re: flight time
I think I might go to work tomorrow and taxi around for the day.  Only 8 hrs though for single pilot.
Re: flight time
Brian, how can I tell if I'm Jewish?
Are you Jewish?
No.
You're not Jewish.
Thanks.
Are you Jewish?
No.
You're not Jewish.
Thanks.
				Approach Ban
Re: flight time
CAR 101.01
"air time" - means, with respect to keeping technical records, the time from the moment an aircraft leaves the surface until it comes into contact with the surface at the next point of landing; (temps dans les airs)
"flight time" - means the time from the moment an aircraft first moves under its own power for the purpose of taking off until the moment it comes to rest at the end of the flight; (temps de vol)
I guess you could. I sure wouldn't. Who is going to care about .3 of taxi time?
AB
				paydaymayday
Re: flight time
Is said person really that hung up for a 0.3?
The things you hear...
Re: flight time
The student who gets the pleasure of paying for that .3 would care.Approach Ban wrote:Who is going to care about .3 of taxi time?
Some people are like slinkies, they serve no purpose, other than to make you smile when you push them down the stairs.
If yer gonna be dumb.....you gotta be tough.
- Prairie Chicken
Re: flight time
What flight?"flight time" - means the time from the moment an aircraft first moves under its own power for the purpose of taking off until the moment it comes to rest at the end of the flight;
Prairie Chicken
				pilotman15
Re: flight time
Airplane sure did move under it's own power but never ended the "flight". I don't think you could log it but in reality no one cares about .3 and if that 0.3 will be the difference between an ATPL/CPL/PPL I would be impressed.square wrote:Flight time is defined as the period of time from when the aircraft moves under its own power for the purpose of takeoff until the aircraft comes to a stop at the end of the flight. It's loggable. And I wouldn't call it padding the book at all, presumably they decided to decline the flight for a reason, and that's experience whether they got stick time or not.
				indieadventurer
Re: flight time
it was 0.8, tower was "too busy" and had them holding in the taxi way waiting for T/O. after half an hour of waiting they came back. (student wasn't charged for that)
Re: flight time
In the Journey Log Airtime = Wheels up to wheels down, Flight time = Everything to get to and from that position.
Flight time goes down into the logbook.
Re: flight time
If the time put in the journey log is marked as "Taxi only" and the student wasn't charged, there shouldn't be any record of the student having used the plane. At my school, if the aircraft doesn't take off and the lesson wasn't intended to practice taxiing (if a mechanical issue was found, for example) then there is no record that the student was in the aircraft. If TC double-checks his logbooks with the school's records, they'll find no evidence of those flights.indieadventurer wrote:it was 0.8, tower was "too busy" and had them holding in the taxi way waiting for T/O. after half an hour of waiting they came back. (student wasn't charged for that)
Re: flight time
No Flight, No Timeniss wrote:Flight time goes down into the logbook.
Why is this even a question, Does 0.8 matter? Who is this desperate for time?
As Modi pointed out, if it didn't go into the Journey Log, it doesn't go in yours.
Lurch
Take my love
Take my land
Take me where I cannot stand
I don't care
I'm still free
						Take my land
I don't care
I'm still free
Re: flight time
...no kidding,eh!!Phillyfan:Tell your friend he's "a loser" and to "get a life"
Keep the dirty side down.
Re: flight time
I remember in the early years of getting my PPL when I couldn't imagine not writing .3 down.Lurch wrote:No Flight, No Timeniss wrote:Flight time goes down into the logbook.![]()
Why is this even a question, Does 0.8 matter? Who is this desperate for time?![]()
Lurch
If you startup, taxi, runup, taxi to position, then the weather goes for shit so you scrub the flight is this going into the journey & if so is that not fair to go in the personal log/PTR?
Re: flight time
After a while you will forget where you left your pilots log book and go months without filling in anything.  Comes time to do your medical and you have spent $5000 on fuel with your Visa but only see 20 hours in your log book
				paydaymayday
Re: flight time
Ugh, thanks for reminding me. I haven't put my last 200 hours in. I need to sit down with a 12 pack and some Rub A535 for my writing hand.
AEROBAT wrote:After a while you will forget where you left your pilots log book and go months without filling in anything. Comes time to do your medical and you have spent $5000 on fuel with your Visa but only see 20 hours in your log book
Re: flight time
I will never forget what one old salt told me about logbooks, job applications ect.  The job app. will look good and the log book will seem O.K. but it only takes about 15 minutes in the right seat to see how much B.S. the aspiring pilot has written down.
He called them Parker Pilots. I asked him what did he mean by that? He replied they were flying Parker Pens instead of airplanes! Padding the log book.
Re: flight time
Your school shouldn't charge you for it. Like I said, the entry is crossed out and "Taxi only" put in. Since inspections are done based on air time, and almost no fuel is burned if you don't go to take off power, it doesn't really cost the school anything to run it. Maintenance does the same thing when doing taxi checks. If there's no record that you used the aircraft in the journey log and TC tries to verify that you've actually got those hours, you could be in a bit of trouble. I've heard (rumours are very reliable sources) that someone didn't write down entries in the journey log to save money, but logged the time in his personal logbook. When the records were checked for his ATPL, it didn't add up, and not only did he have to get hundreds more hours, but he received a hefty fine for it.niss wrote:I remember in the early years of getting my PPL when I couldn't imagine not writing .3 down.Lurch wrote:No Flight, No Timeniss wrote:Flight time goes down into the logbook.![]()
Lurch
- tripleseven
Re: flight time
Nice comment. I remember when you got your first flying job. You were just as bad. Didn't you try to log the taxi time as IFR if it was cloudy?turbo-prop wrote:I think I might go to work tomorrow and taxi around for the day. Only 8 hrs though for single pilot.
