Noise powered propulsion
Shiny Side Up
Post by Shiny Side Up »
I just find this thing enthralling. Counter rotating blades are of course double-plus awesome. How coarse the pitch of the blades is when its running is also interesting. The approach segment is different than other airplanes where it seems to push noise ahead of itself.
You probably can't fly in one of them if you have fillings that might come loose, or teeth for that matter.
Re: Noise powered propulsion
The original noisy airplane. Between this airplane and the Grumman Tracker my hearing didn't stand a chance :cry:
Britten-Norman BN2 XL
By a well-known Flight magazine.
Undaunted by technical realities, the design team at Pilatus Britten - Norman has announced plans for the BN2-XL, promising more noise, reduced payload, a lower cruise speed, and increased pilot workload.
We spoke to Mr. Fred Gribble, former British Rail boilermaker, and now Chief Project Engineer. Fred was responsible for developing many original and creative design flaws in the service of his former employer, and will be incorporating these in the new BN2-XL technology under a licensing agreement. Fred reassured BN-2 pilots, however, that all fundamental design flaws of the original model had been retained. Further good news is that the XL version is available as a retrofit.
Among the new measures is that of locking the ailerons in the central position, following airborne and simulator tests which showed that whilst pilots of average strength were able to achieve up to 30 degrees of control wheel deflection, this produced no appreciable variation in the net flight of the aircraft. Thus the removal of costly and unnecessary linkages has been possible, and the rudder has been nominated as the primary directional control. In keeping with this new philosophy, but to retain commonality for crews transitioning to the XL, additional resistance to foot pressure has been built in to the rudder pedals to prevent over-controlling in gusty conditions (defined as those in which wind velocity exceeds 3 knots).
An outstanding feature of Islander technology has always been the adaptation of the O-540 engine which, when mounted in any other aircraft in the free world (except the Trislander) is known for its low vibration levels. The Islander adaptations cause it to shake and batter the airframe, gradually crystallise the main spar, desynchronise the accompanying engine, and simulate the sound of fifty skeletons fornicating in an aluminium dustbin. PBN will not disclose the technology they applied in preserving this effect in the XL but Mr. Gribble assures us it will be perpetrated in later models and sees it as a strong selling point. "After all, the Concorde makes a lot of noise" he said, "and look how fast that goes."
However design documents clandestinely recovered from the PBN shredder have solved a question that has puzzled aerodynamicists and pilots for many years, disclosing that it is actually noise which causes the BN2 to fly. The vibration set up by the engines, and amplified by the airframe, in turn causes the air molecules above the wing to oscillate at atomic frequency, reducing their density and creating lift. This can be demonstrated by sudden closure of the throttles, which causes the aircraft to fall from the sky. As a result, lift is proportional to noise, rather than speed, explaining amongst other things the aircraft's remarkable takeoff performance.
In the driver's cab (as Gribble describes it) ergonomic measures will ensure that long-term PBN pilots' deafness does not cause in-flight dozing. Orthopaedic surgeons have designed a cockpit layout and seat to maximise backache, en-route insomnia, chronic irritability, and terminal (post-flight) lethargy. Redesigned "bullworker" elastic aileron cables, now disconnected from the control surfaces, increase pilot workload and fitness. Special noise retention cabin lining is an innovation on the XL, and it is hoped in later models to develop cabin noise to a level which will enable pilots to relate ear-pain directly to engine power, eliminating the need for engine instruments altogether.
We were offered an opportunity to fly the XL at Britten-Norman's development facility, adjacent to the British Rail tearooms at Little Chortling. (The flight was originally to have been conducted at the Pilatus plant but aircraft of BN design are now prohibited from operating in Swiss airspace during avalanche season). For our mission profile, the XL was loaded with coal for a standard 100 N.M. trip with British Rail reserves, carrying one pilot and nine passengers to maximise discomfort. Passenger loading is unchanged, the normal under-wing protrusions inflicting serious lacerations on 71% of boarding passengers, and there was the usual confusion in selecting a door appropriate to the allocated seat. The facility for the clothing of embarking passengers to remove oil slicks from engine cowls during loading has been thoughtfully retained.
Start-up is standard, and taxiing, as in the BN2 is accomplished by brute force. Takeoff calculations called for a 250-decibel power setting, and the rotation force for the (neutral) C of G was calculated at 180 ft/lbs. of backpressure.
Initial warning of an engine failure during takeoff is provided by a reduction in vibration of the flight instrument panel. Complete seizure of one engine is indicated by the momentary illusion that the engines have suddenly and inexplicably become synchronised. Otherwise, identification of the failed engine is achieved by comparing the vibration levels of the windows on either side of the cabin. (Relative passenger pallor has been found to be an unreliable guide on many BN2 routes because of ethnic consideration).
Shortly after takeoff the XL's chief test pilot, Capt. Mike "Muscles" Mulligan demonstrated the extent to which modern aeronautical design has left the BN2 untouched; he simulated pilot incapacitation by slumping forward onto the control column, simultaneously applying full right rudder and bleeding from the ears. The XL, like its predecessor, demonstrated total control rigidity and continued undisturbed. Power was then reduced to 249 decibels for cruise, and we carried out some comparisons of actual flight performance with graph predictions. At 5000 ft and ISA, we achieved a vibration amplitude of 500 CPS and 240 decibels, for a fuel flow of 210 lb/hr, making the BN2-XL the most efficient converter of fuel to noise after the Titan rocket.
Exploring the Constant noise/Variable noise concepts, we found that in a VNE dive, vibration reached its design maximum at 1000 CPS, at which point the limiting factor is the emulsification of human tissue. The catatonic condition of long-term BN2 pilots is attributed to this syndrome, which commences in the cerebral cortex and spreads outwards. We asked Capt. Mulligan what he considered the outstanding features of the XL. He cupped his hand behind his ear and shouted "Whazzat?"
We returned to Britten-Norman convinced that the XL model retains the marque's most memorable features, whilst showing some significant and worthwhile regressions.
PBN are not, however, resting on their laurels. Plans are already advanced for the Trislander XL and noise tunnel testing has commenced. The basis of preliminary design and performance specifications is that lift increases as the square of the noise, and as the principle of acoustic lift is further developed, a later five-engined vertical take-off model is also a possibility."
fanspeed
Post by fanspeed »
You made my morning-thanks!
AirFrame
Post by AirFrame »
That Tupolev has to have the slowest-retracting and -extending gear that i've ever seen.
7ECA
Post by 7ECA »
AirFrame wrote:That Tupolev has to have the slowest-retracting and -extending gear that i've ever seen.
Countered, with those lovely green rims that all ex-Soviet aircraft seem to have.
Shiny Side Up
Was never sure what Russian aviation's preoccupation with that specific color is. Specifically, its Chromite Green as I recall from painting model airplanes.
7ECA
Post by 7ECA »
Big, strong, simple, easy to fix, like Ukrainian tractor.
Or Ukrainian babushka, but that's another story...
Old Dog Flying
Post by Old Dog Flying »
During the "good old days" when the Backscatter radar was being developed the argument against it was "Why spend all that money when all you have to do is open the window and you can hear the damned things coming for 3 hours before they get here!"
Barney
cgzro
Post by cgzro »
I'm reminded of a fly-by last year. Lancaster, spit, hurricane, p40, p51.. Ie 8 x 2000hp rumbling away followed by a lone Harvard.. Guess which one you could hear. Mind you the Harvard is not very noisy or rough from inside the aircraft , presumably because the noise is all from the prop tips. You can even hear it when in formation next to or behind it
We had a Harvard at SAIT when I went to school there. We also had a 185. Guess which one won the noise war on a cold winter's day doing runups? :wink:
7ECA
Post by 7ECA »
The Harvard is for sure propelled by noise alone, then again I've never had the displeasure of experiencing the Islander, so it may very well be worse...
I've been standing out on apron one at CZBB, just off of runway 07/25 as a Harvard took off, it was awesome, but man did my ears ring for a while after that. P&W turning fuel into noise. :prayer:
Old Dog Flying
You ain't heard nuthin' until you've flown in a Noisy North Star. And yep the Hazard is noisy but fun
Barney
cgzro
Post by cgzro »
Speaking of contr-rotating props, there are some good descriptions of problems with them when they first appeared on the later model Spitfires. Apparently the internal coupling gear that drove the second prop was prone to loosing teeth leaving you with a windmilling forward prop and a driven rear one.. Apparently the combination was barely enough to stay airborne even at full power.
Would have loved to hear one of those on a spit, I bet the noise combined with the Merlin was awesome!
Old Dog Flying
The dual props were installed on a Spitfire/Seafire Mk(?) 47 but actual Mk slips this old brain. This was on a Griffon engine Seafire in an attempt to counteract torque on take-off or wave-off
Barney
cgzro
Post by cgzro »
Yes of course the Griffon. I think it was more than just torque, likely necessary as hp increased and with limited ground clearance for bigger props to absorb the hp.
Yes is was more than just torque. The Avro Shackleton has counterrotating props too and torque wouldn't be an issue with that aircraft.... and while ground clearance wasn't as much of an issue... the clearance between the nacelles and the fuselage originally designed for Merlins, was.
