Brampton Private Cessna 172D down Oct 18 2012
GyvAir
Re: Brampton Private Cessna 172D down Oct 18 2012
Post by GyvAir »
Colonel Sanders wrote:...you could start one
Sabre with another by putting a running one
ahead of the one you wanted to start.
I'm sure TC wouldn't like that, so don't do it.
I've been told that Canadair has a published procedure for starting the Challenger/CRJ series aircraft using that method.
Koopa
Post by Koopa »
Colonel Sanders wrote: When my father was flying Sabres in Europe,
if the starter cart busted, you could start one
http://youtu.be/RXU4fRNFS1U
Looks safe.
plhought
Post by plhought »
GyvAir wrote: I've been told that Canadair has a published procedure for starting the Challenger/CRJ series aircraft using that method.
It's called a buddy start and isn't like what the dear Col. stated.
It involves a typical (and extra-long) air-start hose with two couplings and a funky fork that allows bleed air to flow from the "donor" aircraft to the dead one. Same procedure works with lots of aircraft.
I'd bet you'd some pretty high temps though starting the ol' 'buddy-Sabre' way! :D
GyvAir
Post by GyvAir »
"It involves a typical (and extra-long) air-start hose with two couplings and a funky fork..."
Nestling right up behind another CRJ that's pulling a bunch of power sounds a lot more interesting though... especially if there are passengers on board. Hooking them up with approved bleed air air-start hoses sounds rather proper and civilized. Hardly cheating at all.
Sidebar
Post by Sidebar »
Getting way off topic here, but ...
Buddy start was an approved procedure on the C-130 if your starter was shot. Likely still is.
http://www.youtube.com/watch?v=bXj0sQzljUw
