https://globalnews.ca/news/9526871/toro ... ellations/
Westjet Cancels all flights, due to YYZ Winter Storm
- rookiepilot
Re: Westjet Cancels all flights, due to YYZ Winter Storm
Bit of click bait there rookie, the article clearly says cancels all flights after 8 pm, which is about 20% of the days flights, or 12 departures and 15 arrivals tonight.rookiepilot wrote: ↑Fri Mar 03, 2023 4:55 pm However, the bus may be available…….![]()
- rookiepilot
It’s 7 pm…..just posted it. A joke…..cdnavater wrote: ↑Fri Mar 03, 2023 5:08 pmBit of click bait there rookie, the article clearly says cancels all flights after 8 pm, which is about 20% of the days flights, or 12 departures and 15 arrivals tonight.rookiepilot wrote: ↑Fri Mar 03, 2023 4:55 pm However, the bus may be available…….![]()
And?rookiepilot wrote: ↑Fri Mar 03, 2023 5:14 pmIt’s 7 pm.cdnavater wrote: ↑Fri Mar 03, 2023 5:08 pmBit of click bait there rookie, the article clearly says cancels all flights after 8 pm, which is about 20% of the days flights, or 12 departures and 15 arrivals tonight.rookiepilot wrote: ↑Fri Mar 03, 2023 4:55 pm However, the bus may be available…….![]()
There’s still several arrivals and at least one departure, so are you Fox News, trying to hype things up, it’s called click bait for a reason!
Why not say, cancelled remaining flights, no, you chose to say all flights
- Daniel Cooper
That's not going to play well on Twitter
- rookiepilot
Sunny here now. Are the busses running?
I'm sure WestBus is still running.
Blackdog0301
Bus or plane, at least everything is staying out of the grass and on the pavement.
Not sure your airline can point fingers on that one, what are you up to 3 panes in the grass now? I can still laugh at the joke.Blackdog0301 wrote: ↑Sun Mar 05, 2023 9:13 am Bus or plane, at least everything is staying out of the grass and on the pavement.![]()
