One VERY lucky deckhand...
This forum has been developed to discuss helicopter related topics.
Post by sky's the limit »
looproll
Post by looproll »
that's a dangerous way to shave!
damn hippies... ;)
Donald
Post by Donald »
:shock: What a lucky (good?) heli-pilot as well!
LUCKY bastards!
-istp :shock:
Tui
Post by Tui »
Now, someone correct me if I'm wrong but, if you watch closely during the slow-mo it looks like the tail rotor stops (on the second hit, just after it starts to yaw). Isn't the tail rotor mechanically connected to the main rotor (just geared down)? I didn't think that was possible (without breaking teeth off of gears or shearing drive shafts I guess).
rotorfloat
Post by rotorfloat »
You gotter Tui, I'd say the driveshaft sheared when the tailrotor contacted the deck. If you saw the driveshaft on a light piston like that, you'd understand.
I wouldn't doubt that some damage was done to the gearboxes as well, but not to worry, the entire drivetrain has to be yanked after a strike like that.
2milefinal
Post by 2milefinal »
Every time I watch that vid I cant believe that guy at the rear does not get killed. :?
pilotdreams
Post by pilotdreams »
Did the pilot take off or did the helicopter get thrown off? Looks to me like it came off the deck when the boat went down after the swell had passed.
FreaKy_DeaKy
Post by FreaKy_DeaKy »
wow.
cheers to those boys for making it outta that one.
That's gotta be a huge inspection
Fully Articulated
Post by Fully Articulated »
Nets are good, Nets are good, Nets are good!!!!
Post by ahramin »
Care to post a little more about the nets? Is it just that helipads are designed slippery by mistake and a net fixes that or what?
Fully Articulated
Steel Helipad + Skid Helicopter = Low Coeficient of Friction
The nets increase the friction preventing sliding in rough conditions or rotating during Nr increase or decrease. I have seen a jetranger spin 90 degrees while spooling up (a bit to quickly).
I am convinced that if the net seen in the video was not there we would be watching a helicopter swimming video.
I spun 180 degrees on ice DURING startup once... pretty slick...!
STL
Post by ahramin »
Is anyone making helipads out of something other than steel or do i see a business opportunity here?
Return to “Helicopter Forum”
