C-5 Galaxy taking off with a faulty undercarriage Problem
ravitokas90
C-5 Galaxy taking off with undercarriage retraction problems.
In that situation, they can probably get the gear back down OK. And if not, they can land on 3 main gear as long as they go easy on the sink rate. Both have happened before. The C-5 has a history of gear retraction failures, especially in the budget-strapped 1990s when gear components were being pushed to their repair limits and beyond. When the USAF was able to get new parts into the inventory in the 2001-2006 time frame, retraction failures dropped drastically, but they still happen from time to time. That landing gear is huge, has complex hydraulics and electrics all over it, and is more complex than many entire aircraft systems.
C-5 Galaxy Fatal Incident Video
- Flying Low
Re: C-5 Galaxy taking off with a fatal undercarriage Problem
Fatal???? Did I miss something?
linecrew
I'm guessing it was a typo and should have read "faulty" instead of fatal.
ravitokas90
yes,that should be "faulty" instead of ''fatal''
But then also ,I think that's a big deal!
