Use the sim for procedures. Before you get all spooled up, here's a few things to do
learning how to manage a twin, fly it IFR and do both while communicating are tough things to do. If you review the list of things I gave you, you may think there is about 4 hours study per hour of flying. It's closer to six. Flying a twin, flying IFR and managing the whole thing are three separate things. Expect it to come together slowly.
Avionics
• Know how an HSI and RMI work
• Get manual and copy it or download one at Garmin.com
- Know how to select airport, create & modify a flight plan, select an approach, verify waypoints, verify Raim, know the different NAV pages, run biggest GPS in MAP mode. Build a Q-card for set-ups
There is a desktop simulator you can download for Garmins. You really should download and practice.
Scan
You will naturally tend to look at the instruments dead ahead of you, and miss the ones even ten degrees out of your field of view. Learn to look at the basic six-pack, coming back more often to the attitude indicator. From there, learn to expand it periodically to the engine cluster, and annunciation panel. Knowing where switches and selectors are by touch will mean your focus can be on the primary instruments until the item is touched. Then quickly make the change or correction you wanted, and return your attention to the attitude.
Bad scan= bad day
• Approaches
- most 704 companies use AMORTSS as the approach briefing format. Learn to use it automatically. Dunno what the school uses, but the Group I is 40 hours, and your career is 20000 hours.
- Learn ABC ATIS, Briefing, Checklist
. DO NOT start approach without this!
- Single pilot use Autopilot during radio set up.
Flying out of Springbank, there are approaches at Drumheller, Red Deer, Calgary, and Springbank. Practice briefing and setting up each one. Brief them out loud recording then with your phone, and okay them back to see if they cover everything.
- Clearance shorthand. There is a short form of almost every part of a clearance. Learn them and make a Q-card! Practice copying clearances for a few minutes Every day! FTGU has a section on it.
The Internet
You can create flight plans at Fltplan.com
When you do, it allows you to select instrument approach plates, airport charts, arrivals, departures, certify Raim availability, and often give you performance and fuel burns to contrast with your own flightplaning. It also allows you to print off a Takeoff & Landing Distance (TOLD) card. This will give you ATIS freqs as well as all the freqs you need in order, with an organized spot to write it using ATc's framework, then copy the clearance in their framework. You really should use this every flight!
Www.icpschool.ca
It is where I learned to be a check pilot. There is terrific source information about how approaches are designed, certified, assessed, as well as exams that really comprise the IFR and ATPL exams.
• The Aircraft
- Has limitations, speed weight Takeoff Distance, Landing, engine values. Do not go flying in the aircraft until you know them, or you are throwing away your
Money!!!
-Learn the location of: Boost pump switches, Master, alternator switches, avionics master, throttle Prop and Mixture, Firewall shutoff, and Crossfeed! Learn the location blindfolded before you go flying! Take pictures of all of these and the circuit breaker panel. Print them at Staples. Review them daily.
Most light twins have power settings for the hold, leveling on a non-precision approach, approach descent on one engine, and go around. Usually with a certain attitude. Learn these and write them on a QCard.
• Simulator
Does not fly like an airplane at the training level. It is for procedures training
.1. Learn the procedure
2. Practice it in the sim or CPT by touch calling and confirming each item as you go. Be able to do it blindfolded.
3. Get it comfirmed and set inYour head in the Sim.
4. Only then should you try it in the Aircraft.
• Emergencies
There are Drills and Checklists
-drills require you to know them by heart.
-checklists may be performed after a flow and read, but it may be easier and smarter to say and do each item to confirm that each has been done.
-notice I say the word Confirm a lot? Touching any engine control for an emergency without confirming it is the correct one is often why people shutdown the good engine.
SOPs
While I can email you ours, your school should have their own SOPs. Learn them. It is the way we do business. Flying with someone who doesn't know their SOPs and follow them wastes your time, encourages a bad habit and is not good for the safety of your aircraft.
The Ride
We need to see:
A knowledge of
The aircraft limitations
CAP Gen Alternate, takeoff alternate, landing, takeoff below re-land limits, LVOP & RVOP, approach limits
Systems and instrument checks. If you don't check on the ground, you can't use it in the air
2 Stalls
2 Steep Turns
2 takeoffs
2 landings
One balked landing
One missed approach often with an engine failure on the missed
1 ILS
One non precision, preferably circling approach
For my rides, the ILS is usually single engine
The circling approach is often flapless
Three to four other un-related systems failures: Electrical, Hydralic, communications, instrument (failing the HSI for instance)
If you practice to the point you can do this confortably, good! You will have a ride line this every six months until you retire!
