I responded with information that prior to Delta's new contract, their pay was not double WJs. (I didn't justify it, I didn't say we didn't deserve it, I didn't say it was ok or not, I simply said that they didn't make double of what we made).RiskyBalloon wrote:
This may be true, however a 34% increase on a salary that is double ours will result in a very different increase. It would be in effect a 68% increase on an equivalent Canadian salary. The gap would then continue to widen.....
RiskyBalloon provided a constructive reply that continued the discussion.
Renelevesque seemed to have missed that point. That BEFORE Delta's 18% initial pay raise, they were not making double of WJ. (again, not justifying or saying we're not worth it, just setting the reference point for the comparator).
For reference, here are the most recent US airline pay rates for 4th year FOs:renelevesque wrote: ↑Thu May 25, 2023 3:50 pm
US airlines 4th year Narrowbody FO rates are about $200 US
Westjet is/was $96 Canadian
That is over double without any exchange taken into effect
As for you MMG point, there is a global pilot shortage so they aren't flying min blocks. But most importantly, working more is not a pay raise
A pay raise is when you make more per hour. Not when you spend more days at work
And with a massive labour shortage, and a critical pilot shortage, you should be seeing substantial pay raises
15.5% is not that. Not even close.
Delta 737 - $169 before their most recent 18% increase, $198 now
Frontier – $130
Southwest - $154
JetBlue – $162 prior to their increase, $180 now (11% increase)
Allegiant - $116
Spirit - $130 prior to their increase this year, $165 now. (27% increase)
These are higher than Canadian rates. We should strive for them. But no, none of them PRIOR to the recent increases were double WJ.
As we all wait and see what the new pay scales will be, when they come out, there will no doubt be "weeping and gnashing of teeth" and arguing over whether the pay scales should or should not include the additional 9.1% for the WSP contribution or not. That being said, if you take WJ's current 4th year FO rate, multiple it by 15% and 9.1%, it puts it just above Allegiant, around Frontier and just below Southwest Is that good enough? Maybe, maybe not.
You know there's a difference between blocking/scheduling window and MMG, correct? They are two very different things. MMG is the minimum you will get paid if you work LESS than the blocking/scheduling window. And, traditionally, MMG is what gets used to determine yearly salary. Ability to be scheduled higher, or pick up OT will obviously increase yearly pay. Comparing pay at MMG is not "WJ makes you work more to make less". I'm not sure how you understood my post for me suggesting that it's a "good thing". Comparing MMG to MMG yearly wages is a pretty standard, yet very imperfect way to compare.
.noreasterYHZ wrote: ↑Thu May 25, 2023 4:23 pm Delta may make more than other US airlines but not by 200%
The fact WJ pilots make less then Delta pilots like SouthWest does, doesn't mean it is ok that WJ pilots make 50% of what Delta pilots do
SouthWest pilots are at least in the same ball park
Stop rationalizing brutal pay
Its embarrassing
Can't really see how I was rationalizing anything, simply setting out proper comparators. That's the key of any negotiation. There are other airlines in the US other than Delta and that's what most folks seem to be comparing to. Fair enough as they lead the pack. Never said the status quo was "ok". Jumping to conclusions is embarrassing.
