Is 12500 still going to be limit for light and medium
ddiggler
Post by ddiggler »
Somebody told me yesterday the B350 and J31 would no longer be medium weight aircraft as the limit would be pushed beyond 15400. Could this be true.
Is that your mom?
TopperHarley
Post by TopperHarley »
According to TC, a heavy a/c is one which weighs more than 12,566lbs (5700kg). It's somewhere in CARs 101, defintions.
Aircraft that weigh more than 12,500lbs are certified as a transport category a/c, which is not the same thing necessarily as a "heavy" a/c.
I could always be wrong though, so hopefully someone out there more knowledgeable will pitch in.
Sure Shot
Post by Sure Shot »
dont these define the different categories:
/H – HEAVY, to indicate an aircraft type with a maximum certificated takeoff mass of 136 000 kg (300 000 lbs) or more.
/M – MEDIUM, to indicate an aircraft type with a maximum certificated takeoff mass of less than 136 000 kg (300 000 lbs), but more than 7 000 kg (15 500 lbs).
/L – LIGHT, to indicate an aircraft type with a maximum certificated takeoff mass of 7 000 kg (15 500 lbs) or less.
turbine works fine
Post by turbine works fine »
HEY Ddiggler...u dont believe me!!!!!!!!!!!:)
hydro
Post by hydro »
We (at Navcanada) received a memo saying the same thing, that "transport Canada has approved the use of ICAO wake turbulence categories". 7000kg/15500 lbs In our case its effective immediately.
hydro
MCA
Post by MCA »
exact. the SW4 and JS31 now fall on the limit of Light/Medium, according to that memo.
I'm intercontinental when I eat french toast
No more BS
Post by No more BS »
14500lbs SW4 is L,
16000lbs SW4 is M
8)
"Flaring is for sissies. I've flown both onspeed and flared approaches....and I'd take onspeed anyday."
(Excerpt from a Naval Aviator web Forum)
grimey
Post by grimey »
You'll be catagorized as what you file. So if you're an SW4 and file as a M, that's what you'll be.
ddiggler
Post by ddiggler »
As I see it, there are weights categories for wake turbulence thence H, M and L. As C-HRIS mentionned, if I can read well, the transport weight categories are a differet scale and applies as before.
So flying a J31 or B350 or anything heavier than 12500 counts as Medium time.
Just asking because it would not make any sense to run after a medium capt job if it ain't medium any more
BTW Turbine Works Fine, hope you're wrong cuz cerveza is going to flow on your bill.
Is that your mom?
CD
Post by CD »
Interesting...
The TC AIM RAC 3.16.3 Item 9 contains different category weights than does the Standard 821 under Definitions. Perhaps some folks at TC in Air Navigation Standards need to talk with each other... :?:
TC AIM RAC 3.16.3 Item 9: Number and Type of Aircraft and Wake Turbulence Category
CAR Standard 821 - Canadian Domestic Air Traffic Control Separation
MCA
Post by MCA »
yeah... and those definitions still include "RVSM Transition Area", which is now outdated by almost 2 years!
good job, guys.
TopperHarley
CD wrote:Interesting...
15,000lbs is an ICAO classification. 12,500lbs is a Transport Canada classification.
Also, these weight classifications are for wake turbulence only.
giligan
Post by giligan »
You guys are talking about 2 different things.
NAV Canada talks about a light as 15500 or less.
TC says you need an ATPL to fly something over 12500.
Wake turbulence and Licence category. Two different things. IMHO
gil
Scuba_Steve
Post by Scuba_Steve »
Am I wrong or did they not remove the 12500 resitriction from the ATP and make it based on an Aircraft with a Minimum flight crew of 2 or more?
I flew a 350 w/o an IATRA, but its MFC of 1 not 2
I just asked yc gnd about this on friday and he said it's a new thing handed down to ATC from Navcan that the classification on light and medium changed for wake turbulence seperation. He said the pilot can waive the 3 minute light behind a medium for intersection departures but not the 4 nm. (RAC 4.1.1, AIR 2.9)
Was there a crash casued by this or something? Is this just another way for controllers to not have to "work soo hard" maybe?
zzjayca
Post by zzjayca »
The briefing we received at work said the change was implemented to bring us in line with the ICAO wake turbulence weight categories.
Jerricho
Post by Jerricho »
Just to echo zzjayca, as of October 25, the ICAO wake turbulence categories/weights are now being used as opposed to the previous TP143 descriptions. The new CAATS software has the ICAO numbers in it (and has from the start which did cause warnings when a filed turbulence category differed from the data base).
Wake turbulence is certainly viewed differently in different countries. The UK has 4 categories (Light, Small, Medium, Heavy) and Heathrow actually utilizes 5 (Light, Small, Lower Medium, Upper Medium Heavy). The 757 falls into the "Upper Medium" category, and there are major differences in spacing required on final approach for all the types. Here in Canada a light behind a heave requires 6 miles, in the UK it's 8.
