Why you should always know where the sandbars are!!!!
http://www.lantz.ca/imagesMoosonee/2009 ... _-0011.jpg
Hit a submerger shoal just short of a sandbank.
Re: Why you should always know where the sandbars are!!!!
A good reason for not alighting with full flap in a 206 as well!
We took the rear seat besides the back door out as a safety measure.
- Shiny Side Up
Weren't all the U206s supposed to be refitted with the door that could be opened with the flaps deployed?MichaelP wrote:A good reason for not alighting with full flap in a 206 as well!
How exactly would that work? cut a nice angled chunk out of the forward rear door maybe - might get a bit drafty
Been a while since ive been around a 2x6 but thats my best recollection.
You will never live long enough to know it all, so quit being anal about it..
i thought they had to put in a co-joe door retrofit... $$$ as i recall...
Looks like the water rudders are in the down position...........I'm not a float pilot but i do know that's bad on landing or takeoff.
Leaving water rudders down for take-off is no big deal in my experience. They just ride up and skip along the water anyway once you speed up. I use to do it intentionally just to see if there was any advantage. But it was always a case of beer if someone caught you.
- Shiny Side Up
The ones I've seen refitted have the pair of doors changed so they overlap differently. This enables you to still open the front of the pair fully and the rear one slightly as to still be able to egress the opening if the flaps were deployed. The rear of the doors still must be opened first, but in the old set up, when the flaps were down, couldn't be sufficiently opened to free the front of the two doors.fogghorn wrote:How exactly would that work? cut a nice angled chunk out of the forward rear door maybe - might get a bit draftyBeen a while since ive been around a 2x6 but thats my best recollection.
