Okay, so it's an easily identifiable landmark, but does that mean that you can only practice your exercises above it?
Do you only fly over Crescent Island because it makes giving any radio calls to local traffic really easy with regards to your location?
And for the geographically unaware, Crescent Island is actually outside of CYA126(A). No biggy here, unless of course you're doing any aerobatics (e.g. spins). See CAR 602.27 (below):
Aerobatic Manoeuvres - Prohibited Areas and Flight Conditions
602.27 No person operating an aircraft shall conduct aerobatic manoeuvres
(a) over a built-up area or an open-air assembly of persons;
(b) in controlled airspace, except in accordance with a special flight operations certificate issued pursuant to section 603.67;
(c) when flight visibility is less than three miles; or
(d) below 2,000 feet AGL, except in accordance with a special flight operations certificate issued pursuant to section 603.02 or 603.67
AND CAR 603:
"aerobatic manoeuvre" means any manoeuvre in which the aircraft bank angle exceeds 75 degrees or the pitch attitude exceeds 60 degrees above or below the horizon. Examples of aerobatic manoeuvres include, but are not limited to: rolls, loops, spins, hammerhead turns, tail slides, and lomcevaks
A quick check of the Vancouver VTA will confirm that the airspace in the vacinity of Crescent Island is controlled at and above 1200' agl. (if you don't know why, then PLEASE ask a flight instructor.
Okay, so dual spins can be covered by Flight Training, but solo spins - NO!
On a more common sense issue, those strange people who like to fly floats tend to follow the river low level in this area. Having an aircraft spin down towards them, only 1000' - 1500' above their heads tends to lead to brown pants! So, come on, lets use CYA126(A) for its designated use!
On another note, anyone fancy starting a rant against the use the term "Glen Valley International"?
