King Air at Gillam, MB
Re: King Air at Gillam, MB
You guys all know what this means right???
There is now a Gimli glider and a Gillem glider!
I will now continue to confuse the two towns names forever...
It's easy to remember. Gillam is the one with the smooth runway.
By the above photo, high float landing gear, wing lockers, and 3-bladed props?
That’s gotta be FRMV...
All Canadian runways should start under a lake, so that a failed landing can result in a soft landing howbeit wet one!
Very lucky crew. From the info I’ve been told it’s looking like a fuel issue, and not quality but quantity...
How's that possible? Full mains is plenty for Winnipeg to Churchill.
Roadrunnersmother wrote: ↑Thu Apr 25, 2019 7:23 pmHow's that possible? Full mains is plenty for Winnipeg to Churchill.
Um...perhaps if the mains were not filled?!?! Some of the people who I’ve chatted with said a couple other aircraft heard a low fuel emergency was declared at some point before bouncing it off the lake.
My God how much competance does it take to order full mains in Winnipeg, one pilot watch the fuel person fill the mains and if they didn't bother doing that, look at the fuel gauges when called on the checklist.greygoose wrote: ↑Thu Apr 25, 2019 7:28 pmRoadrunnersmother wrote: ↑Thu Apr 25, 2019 7:23 pmHow's that possible? Full mains is plenty for Winnipeg to Churchill.
Running out of fuel doesn't seem real.
Thanks... I have a lot of time in CGT and ZPW from 15 years ago. Tough to see that happen to a company I spent over 6 years at.PostmasterGeneral wrote: ↑Thu Apr 25, 2019 6:22 pm By the above photo, high float landing gear, wing lockers, and 3-bladed props?
No CADORS?
Accident speculation:
Was that the route? I thought it was a flight from somewhere in Nunavut to Winnipeg.Roadrunnersmother wrote: ↑Thu Apr 25, 2019 7:23 pmHow's that possible? Full mains is plenty for Winnipeg to Churchill.
I wonder if there’s any connection?
http://www.avcanada.ca/forums2/viewtop ... 31715
The ad probably has to do more with the pay and morale, than the accident.
Bork Bork
I'm not saying that it is what happened but the routing it sounds like from the RCMP was YWG - YYQ. If this aircraft landed in YWG with YBR or YQK as an alternate thats about 30-45 ish mins of gas + 45 mins of reserve gas... about 1:30 will get you awfully close to Gillam if fuel was ordered in YWG but never arrived.
Does the route make any difference if you don't have enough fuel to finish the flight?
CGT is mothballed outside the shell hangar in YWG. Missing it’s engines, tail, etc.FICU wrote: ↑Thu Apr 25, 2019 7:59 pmThanks... I have a lot of time in CGT and ZPW from 15 years ago. Tough to see that happen to a company I spent over 6 years at.PostmasterGeneral wrote: ↑Thu Apr 25, 2019 6:22 pm By the above photo, high float landing gear, wing lockers, and 3-bladed props?
ZPW is still flying as far as I know.
RIP CGT... it was a workhorse!PostmasterGeneral wrote: ↑Fri Apr 26, 2019 1:00 pm CGT is mothballed outside the shell hangar in YWG. Missing it’s engines, tail, etc.
- IMG_0089.JPG (462.83 KiB) Viewed 3390 times
- IMG_0069.JPG (474.58 KiB) Viewed 3390 times
One of the nicest flying straight -200’s I ever had the pleasure of driving. Serial number 003 was she?
Was at Wasaya before KAL got it. I really enjoyed the performance it had with the Raisebeck mod and 4 bladed props and no autopilot. A completely different animal to ZPW. Those photos were taken from ZPW on a return flight to Rankin from Churchill. John F. was flying CGT with Tanice and I had Tim P. with me taking the pics. We had some formation fun and great times when it was a Mom and Pop company!
A couple more for nostalgia...
- IMG_0091.JPG (472.67 KiB) Viewed 3036 times
- IMG_0093.JPG (482.04 KiB) Viewed 3036 times
The auxes are transferred directly to the nacelle tank via the jet pump and to the engine. A flapper valve keeps the main fuel from entering the nacelle tank until the auxes are empty and the nacelle level/pressure drops due to the jet pump stopping.goingnowherefast wrote: ↑Thu Apr 25, 2019 3:22 pm Except on a King Air, you transfer the aux fuel into the mains as there's room to accept it. By landing time, they'd long since have emptied the aux tanks and be running on the main tanks. Fuel would have been mixed long ago.
It will be interesting to see what the real investigators discover.
It is possible for main fuel to be contaminated and aux fuel to not be. Unlikely, but possible.
